I have developed a coolant leak, it appears on the left side. I don't think it's the normal under the carb leak, I replaced the hoses under the carbs and the upper and lower radiator hoses less than 1k ago and also resealed the elbows (seperate item but when I pulled the elbows there was no orings or groove for orings in the elbows so I used a silcone sealer).
The leak comes down the left side of the belly pan in front of pegs and sidestand so I'm assuming it's not under the carbs.
The odd thing is it drips about a tablespoon of coolant when cold then it stops once it's even slightly warm. I notice in the schematics there is a metal pipe from the lower radiator hose to the block, anyone experince leaks here?
Any ideas before I pull all of the plastic? I thought I would ask so I could have any parts needed in hand before starting.
