I keep getting water inside my headlight shell. Has anyone else had this issue? I have blown (broken) two bulbs in the last year due to moisture on the hot glass. Plan to replace it but it will be a PITA.
I just cut the lower tabs off the H4s and installed that way.
.... Funny, I have never used anytrhing but standard H4 Oshram 60/55W bulbs. ...
Maybe he means a standard H4 as in not a 100/70 H4. If he bought the bike used with an H4 already in it then the confusing makes sense.
Thanks for passing on the apparent cause of the leak. I'm not sure what the adhesive is, but replacing the whole unit just because it needs to be re-sealed seems a little extreme!
Btw, ST1300 headlamp units are not "sealed", they are definitely vented, but in such a way as to prevent water ingress.
Ciao,
