Hi, do you think it would be ok to use non oem parts to refurbish the forks and head bearings? I am looking at parts from wemoto.com
http://www.wemoto.com/amend/
I've used nothing but aftermarket fork oil seals (not sure if you're confusing them with the dust seals, which rarely need replacing) and have had no problems. For steering head bearings I went with aftermarket tapered roller bearings like everyone else here, and since the guy who distributes them lives a few minutes from my house, they were easy to find. Not sure what is available in Europe, Martin (ST1100Y) might be able to help answer that. Never had to replace the other parts you're asking about, so won't comment on those.
Not sure about Ireland, but besides David Silver as source for OEM parts I think Louis might be an option for mail ordering 3rd party/vendor spares; fork seal kit: http://www.louis.at/_10d879e0e13263...&typ_id=ST1100ABS&ADTRACTIONSLOT=detail_xsord , dust cover kit: http://www.louis.at/_10d879e0e13263...c=artnr_gr&artnr_gr=10042050&typ_id=ST1100ABS , and their tampered steering head bearing kit: http://www.louis.at/_10d879e0e13263...c=artnr_gr&artnr_gr=10051190&typ_id=ST1100ABS . They also offer a fork seal driver: http://www.louis.at/_10d879e0e13263....php?topic=artnr_gr&artnr_gr=10003457&lang=en (don't know about its fit or quality though...) Once apart I'd check the fork tubes for any discolorations (like bluish lines/alongside marks) or any pitting due to gravel hits (best for this is to take a cheap pantyhose and rub it gentle over the for tube surface, this fabric will catch/rip on any damaged point); you might also roll them on a flat table plate to check if their bend.Not sure what is available in Europe, Martin (ST1100Y) might be able to help answer that.
just advice from experience.Just suggesting to save ya' some bucks that could be better used for riding fuel
Thanks Brant, the oem seals are a good bit more expensive, though I know from experience in other things, the old rule, 'buy cheap buy twice'
Forgive the stupid question but don't you have to dismantle the forks to change the oil too? LOL you can tell I'm not much of a mechanic!I will also say that I learned a long time ago that changing the oil frequently is a lot easier than dismantling the forks to change the seals after the dirty oil causes them to leak
Not essentially coming only from the head bearings (in fact would this indicate them being in really bad condition...), it could also sum up due worn fork bushings and, in worst case, worn/oval fork bottoms causing additional clearance in the front wheel guidance... which will cause skittish feedback while cornering....side to side the head bearings feel smooth,but catching the bottom of the fork tubes and rocking them forward and back, theres about a 1/4 inch of play...
http://www.louis.at/_10d879e0e132636...T=detail_xsord
The dampening orfices get enlarge over years of oil forced thru the small openings caused from friction. Go to a 10w or 15w fork oil after totally clean internally. No actual NEED for fancy progressive springs, unless they are badly sagged, which is very doubtful. OEM fork seals IS your best option for durability, even tho many use aftermarket fork seals. I found this out many a decades ago on moto-x bikes, and street bike are no different. Quality rules in this case, and worth the slight added expense. The anti-dive valves seem to be often neglected, for whatever reasonI haven't a clue, but alot of times cause poor load dampening because they are all gunked up........just advice from experience.Just suggesting to save ya' some bucks that could be better used for riding fuel.
Put the fork in a vise, or if you don't have a vise then hold it on a table as best you can. Or, put it back in the triple clamp to hold it. If you're lucky the bolt will break loose when you torque on it. If you're unlucky it will just spin and not make any progress because the part it screws into is able to spin inside the fork tube. If that happens then you just get out your air tools and hit it with a quick blast on an air impact wrench. If you don't have air tools, then off to the shop to get them to break the bolt loose for you. Also, if you put the spring back in the fork, and put the top cap back on, the pressure of the spring on the fork inner parts might be enough to hold it steady to break the bolt loose with hand tools, so that's worth one last try before taking it to someone with air tools.
