Way high RPM after removing airbox
T_C
St. Louis, MO
2005 St1300
8568
Need some suggestions.
I pulled the airbag off to add in a Rosta cruise.
Reassembled the airbox after double checking all the linkage moves freely.
Start bike, idle sounds high and climbing. Settles in around 4500
After a few minutes it starts dropping as the engine warms. Once I'm at 3 bars the idle speed is down to 2500.
So what the heckler is going on.
What I do know:
Wax cylinder is operating properly.
Antifreeze is good and topped off.
Set idle screw is backed all the way out. Screw it in a bit and engine rpm climbs.
I reattached 3 houses to gas tank.
2 vacuum hoses attached under airbox.
Throttle moves cleanly, butterflies are closing.
Killed and restarted bike, same thing happens.
Let bike cool down completely and the same routine occurs.
Blipping throttle just does what it should.
Did I forget a wire somewhere?
Oh... I checked 5way while in there and clean.
Any help appreciated, especially if it saves me from totally removing the tank.
Thanks,
T
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
My money would be on some part of the air box interfering with the throttle linkage.
A quick way to check that might be to open the air box, put a finger on the bottom, open the throttle and let it snap shut. If you feel a thud, something's holding the throttle open.
--Mark
T_C
T_C
St. Louis, MO
2005 St1300
8568
--Mark
Well the trthrottle feels like it is closing. But obviously something under the tank is the problem.
Lifted the tank just enough to get airbox lid off. Then pulled the front right snorkel tube.
Closed, dang it... going to see if I can pull the rest of the airbox without removing the tank.
Any other suggestions appreciated.
T
v8-7
Bradenton, Fl
Any way you can start the bike with the throttle plates in a known closed position ?
That could point to , or eliminate a vacuum leak of un-metered air
T_C
T_C
St. Louis, MO
2005 St1300
8568
Pulled airbox with tank hoses still connected. Yeah! Didn't know you could.
Butterflies are all closed.
But the small holes for the idle bypass air are wide open. Great! Found out why the idle is so fast. Now what the heck is causing that?
T_C
T_C
St. Louis, MO
2005 St1300
8568
Okay. Of course the idle bypass holes were open. I hadn't warmed up the engine to get them to close yet.
Remove the aftermarket cruise control...
I've seen more than a few of these cause your RPM issues, could be a defective unit, air leak, installed incorrectly etc.
I'd start over, remove the unit and see if it works normal again.
Byron
Moderator
KY
6091
If I remember correctly the Rosta requires a RPM reducer to work properly, was one installed on the tach signal wire? If so was it set correctly, double check.
T_C
T_C
St. Louis, MO
2005 St1300
8568
Not even in Rosta testing/use mode yet. Just firing up the bike after dismantling it for Rosta installation.
Byron
Moderator
KY
6091
If you followed the instructions listed here then my guess would be something pulling on the throttle cable. The vent hose that runs under the front duct of the air box may be the culprit if it didn't get fitted into the part that holds it up.
