Anyone use this???
002760
I have something like that on the vstrom and it works well.
Issaquah/ San Diego
2010 st1300
I have that exact one on my 2010st1300 (&weeStrom) the st I filed the clamp real slim to fit between. Been using for 23k miles
Dahlonega, Georgia
2020 Africa Twin DCT
What are you going to put it on? I would recommend looking at the Vista Cruise if an ST1300, it's just too clean and simple.
LetErBuck
Brian Oehlert
New Hampton, Iowa
2007 ST1300A
http://www.cruisercustomizing.com/motorcycle-cruise-control/part/BAW-MCC?parameter=ppc&utm_source=MSN&utm_medium=cpc&utm_term=brakeaway%20cruise%20control^30512924811&utm_content=4504081093&utm_campaign=Smaller%20Volume%20Product%20Lines^57133
I have been using this for 4 riding seasons. It works well. I have not needed to do any adjustments what so ever.
another link.
http://www.brakeawayproducts.com/
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
I had a Break away on the 01 I had. It worked well for me once the alignment was tweaked well enough. The one the OP posted is similar to it but looks less cumbersome so maybe easier to to get dialed in.
Cheaper than the Break away, so if they will take it back,,,try it and let us know how it works.
San Diego
ST1300/FJR1300A
I tried the omni-cruise, and it works OK, except that you have to use your finger to hold it if you want to adjust your throttle position for less throttle. This puts is a distant 2nd to vista cruise and other locks that you can easily adjust throttle position for minute adjustments.
I had the Brakeaway on the FJR, and it worked well after getting it adjusted right. Still it would disengage a bit too easily for my tastes.
So with all that said, I totally agree with the statement above. Vista is easy to install, easy to use, cheap and effective.
