Could do that, but with system being mostly aluminum, heat expansion of a fracture(coolant elbows) will somtimes not leak unless aluminum metal pieces are heated, having expansion.You might have an airlock in the system, you may have to burb it.
i think you can have the the system pressure tested to determine if you have leaks.
just throwing out some random thoughts
