BakerBoy
It's all small stuff.
Great suggestion to try DD...such a test would eliminate linkage or shift dog and would confirm the shop's belief that it is the clutch.
I am wondering if during that 8000 miles on the bike prior to you owning it someone put in "Energy Saving oil" that caused your problem.
Wouldn't that make the clutch plates slip instead of stick together?I am wondering if during that 8000 miles on the bike prior to you owning it someone put in "Energy Saving oil" that caused your problem.
There it was! the bolt had loosened up just enough that every time he shifted, it was walking off the splined shaft. There was splines showing between the tranny and the lever, and the shaft was recessed inside the lever about a quarter of an inch. I loosened the bolt all the way, removed it, and cleaned and lubricated it, then pushed the arm ALL the way back onto the shaft and tightened the bolt. Smooth as glass shifting once again....or as he says smooth as buttah...
I suspect the shop knows this happens and uses it to their advantage in generating service work.
I also checked my 07 tonight, and sure enough, mine was starting to walk off just a little bit, but enough to bind the shaft movement, despite the joints.
You may want to check this one bolt from time to time. I know I will from now on.
Larry
