I put together a long drawn out description but did not click the correct button so all narrative was lost. In a nutshell, I got my lights...They are awesome and in my haste to get the second one installed, I clipped the TOP tab. I did use some JB weld and reattached it but decided to try using the Honda OEM 45/45 mounting plate. I was able to separate the bulb from the plate and after some grinding and nuance, was able to fit the plastic sleeve from the Evitek mounting plate into the Honda OEM bulb plate. The only thing I need to explore is I had to slide the plastic sleeve in from the front rather than attach it from the back as it is done on the Evitek plate. This will cause the bulb to be inserted about 1/8 inch deeper in the headlight assembly so I will need to evaluate the potential of changed light pattern due to the bulb being inserted further and any problems with additional heat in the headlight assembly becasue it is in further. Time will tell. If problems to present, I still have the Evitek base plate so I can still use that.
Ride Safe.
