New G6 H4 with SHIELD is now availible - no glare no scatter.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Has anyone done a step by step article on this install?
1. Buy the LED Headlights.
2. Remove the rubber covers from the headlights.
3. Remove old headlights
4. Separate the LED Headlights from the holder(base)
5. Install the holders (base) after removing the two bottom tabs (like you have to do with any non-standard H4 bulb)
6. Install the rubber covers over the base, without the LED headlights in place.
7. Install the LED headlights through the rubber covers, into the base. (look through the headlight "glass" for proper alignment.)
8. connect the wires up and zip-tie them up, out of the way.
There you go, instructions how to mount the LED headlights! :D
spiderman302
Camarillo, Ca
2006 ST1300A
002552
From in front of the bike, reach under the head light to replace the light bulb. You will have to rotate the handlebars to move to forks out of the way....
Newport News, VA
2006 ST1300A
1a. Disconnect wires from existing headlight bulbs.
Sorry ... I just had to include a missing step.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Or, as I had to do while on my trip to replace the LED (one was out), pop the mirrors off, remove the windshield, windshield cowl and instruments and everything is right there! ;)
mlheck
Ft. Wayne, IN
'18 BMW K1600GTL
664
WOW, That's like going around the block just to go next door. IMHO
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Yep! Not good for one set/bike and still working on the other bike.
Go back to page 23, my posting at 226 and start looking at my posts from there.
Does anyone know if I can replace the H7 bulbs in my Hella FF50's with the Evitek H7 LED bulb?
I don't know but let me guess. First) high-wattage LED bulbs tend to be longer than the halogens they replace so fitment might be a problem. Second) I wonder about the fan's efficacy in an small enclosed space. Some of these bulbs don't use fans but strips or loops of what looks like flat braided wire as a heat sink. I don't think those would last long.
I'd like to see some Evitek LEDs to replace some H-1 bulbs in some auxiliary lights. I've yet to put them on because they're 55W each. I'm looking for an LED bulb with a fan. Fitting in the housing will be a concern.
st11ray
charlotte, nc
'06 ST1300
7189
Are there any tabs that need to be depressed to get the 3P socket connector? I thought I just pulled them off last time I changed them. They don't want to come off and I'm pulling pretty hard.
New Jersey
st1300 '04
7163
The OEM bulb sockets have tabs that need to be squeezed to remove them. I forget if you squeeze at the front or the back of the connector.
Yes, there are tabs on either side of the 3 pin connector that depress when you squeeze it between finger and thumb.
