TMUS
MSF Instructor 32 years
- Joined
- Feb 21, 2007
- Messages
- 525
- Age
- 69
- Location
- Quincy, Michigan
- Bike
- 2006 ST1300a(Marvin)
- STOC #
- 7054
Ok, water pump leaking, going to install new. Question: 06 has 103,000 should I also do the clutch while in there?
What was the difference? I'm 50k beyond your replacement and my clutch feels like it always did although wear does creep up unnoticed. Other than the obvious slipping or chattering I'm not sure I know what a worn clutch feels like. Almost every ride I practice slow speed maneuvers slipping the clutch against the brake and the friction zone feels like always.I had 116K on my '05 bike and had it down for the waterpump. I went ahead and put a used clutch in (~10K on it) I couldn't believe the difference it made. I didn't know my clutch was getting that bad. One thing about my clutches, I commute 125 miles a day and a lot of that is in slow and go traffic, lots of lane splitting and gear shifting! So maybe mine was worn worse than others, but if I'm in there for the waterpump, and the bike has more than 50K, I'll be replacing the clutch!
They wear slowly and do creep up unnoticed, and you don't really feel the difference until you replace them. As stated in a prior response, often times the plates are still good, but the springs go out of spec.What was the difference? I'm 50k beyond your replacement and my clutch feels like it always did although wear does creep up unnoticed. Other than the obvious slipping or chattering I'm not sure I know what a worn clutch feels like. Almost every ride I practice slow speed maneuvers slipping the clutch against the brake and the friction zone feels like always.
My buddy (just retired after 40yrs as a motor officer and instructor) was the motor Sgt. for the local sheriff's office. He'd take motor officer candidates and teach them to ride before sending them to Motor School. He was also responsible for perishable-skills training afterwards.slow speed maneuvers with ONLY your clutch, and not touch or ride against your brakes. Several courses will not allow you to use your brakes at all, if they see your brake light, you fail.
While several folks teach to use the throttle/brakes to remain in the friction zone, the better riders pin the throttle and just use the clutch (see cone rodeo's for example).
Thanks Larry. I'll try that. As I'm sure you know it's not necessary to ride the brake all the time in slow speed maneuvers and I don't but I'll try and not use it at all and see how that goes.They wear slowly and do creep up unnoticed, and you don't really feel the difference until you replace them. As stated in a prior response, often times the plates are still good, but the springs go out of spec.
I would consider it money well spent to at least replace the springs.
Dave, you should try your slow speed maneuvers with ONLY your clutch, and not touch or ride against your brakes. Several courses will not allow you to use your brakes at all, if they see your brake light, you fail.
While several folks teach to use the throttle/brakes to remain in the friction zone, the better riders pin the throttle and just use the clutch (see cone rodeo's for example). This really does bring your riding skill up a notch or two.
That's what I was going to do at the minimum. Thank allSimilar experience to Roger's. Replaced my pump last spring at 150k. Found the clutch plates about half worn but the springs were at their service limit so I ended up just changing those out. Clutch plate life is highly dependent on how you ride. I would just measure the plates once you open it up and order replacements if needed. They're pretty easy to access once that front cover's off...
You weren't sitting on it then?... no excessive weight.
And if that doesn't work, then you'll have to OPEN it back up and replace the plates! DO IT WHILE IT'S OPEN!Mine does shudder a little on take off, I will replace the springs first. Thanks all
It might cost a few bucks more, but ripping back into it is worse!
Sorry to be so harsh, but if it's opened up, just do it all. Now, about that waterpump.....Fine, deep down I agree with you. It never works out for me cutting corners and or time.
