lost my trunk
California
ST1300@2009
Is that stainless steel? Looks pretty nice!
So you now have 7.7 + 3 = 10.7 gallons which yields about 428 to 450 miles of fuel autonomy (maybe a tad more depending on how you are riding)... Which leads to the question: Are you planning to join one of those iron butt competitions?
Ron
Orlando
ST1100s
2432
What's the weight recommendation for that location?
Looks good! Where are you plumbing into the standard tank?
I'm sure the luggage rack weight suggestion by Honda has been surpassed by almost every rider that has used the luggage rack. I would guess the 3 gallons of gas and tank weight about 30 pounds. My 3.2 gal. aux. tank hangs behind the rear wheel taking the place of the rear fender on my 1100. No problems in years of use.
drbuzzard
42.23n/83.33w/636
'06 ST 1300
8900
haven't thought about any iron butt ride other than maybe a 1500 but the three guys I ride with the most have a fuel, when done we will all carry about the same amount of fuel
drbuzzard
42.23n/83.33w/636
'06 ST 1300
8900
the tank is made of aluminum
my friend has the same setup on his ST 1300 and has not had an issue with the aux tank and fuel
Fort Worth, Texas
91 ST1100/06 ST1300
The ST1300 manual states the weight limit for the aft rack in 20 pounds. On the 1100, the support has been known to crack when overloaded for an extended time....metal fatigue. That's the reason I asked the question.
mlheck
Ft. Wayne, IN
'18 BMW K1600GTL
664
I've run with more than 20 lbs. on that rack for many, many miles with no issue.
Sent from my SM-G935V using Tapatalk
Metro Detroit
St1300
Wow looking sweet. Wonder if it could be powder coated black to match the bike. I went from a 2 gallon tank on my cx to the 7 gallons on the st. An thought that already was huge. I looked at these a few times for the cx. Never got around to actually seeing one. Cant wait to return your seat now so I can check it out.
T_C
St. Louis, MO
2005 St1300
8568
On the 1300 the rack is plastic. No metal fatigue. ;)
Fort Worth, Texas
91 ST1100/06 ST1300
There is a support under the rack that it mounts to with four bolts. That support is bolted to the rear frame. This is the part to be concerned about. I don't know what material the support is since I don't have a 1300 I can't go out and look. On the 1100 the corresponding part is metal. Plastic fatigues (over-stresses, if you will) as well as metal.
Nantahala
2008 ST1300 ABS
Ok, so how do you get the gas into the tank? I see the line but here's the real question: Are you filling the main tanks after they go down about 4 gal or hook it straight up? The rear tank is above the main tanks. That doesn't look like a good idea. Just asking.
drbuzzard
42.23n/83.33w/636
'06 ST 1300
8900
couzinjeff has his fuel cell feeding into his tank ( same setup as mine ), he has been insatllig my fuel cell but he headed south to visit his dad so it will be a couple weeks before he finishes this up
drbuzzard
42.23n/83.33w/636
'06 ST 1300
8900
you are welcome to stop by any time
SE Michigan
2006 Honda ST1300
Most aux fuel cells are gravity feed into the main tank, hence the high mount position. Once the main tank gets low enough, you open the manual valve from the aux tank and let the fuel flow into the main tank. I have one sitting in the garage from my old Triumph Daytona 1200. At 5 gallons capacity, it's too big to use on my ST per the IBA rules for rallying. IBA limits total onboard capacity to 11 gallons.
The tail dragger tanks have an electric pump to push the fuel up and into the main tank.
