- Joined
- Mar 18, 2006
- Messages
- 2,832
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Occasionally I come across a comment - (rarely on this forum however) - which is related to adding pre-load to rear suspension - and it is sometimes described as 'making the suspension stiffer', or 'compressing the spring'.
My own opinion is that both of these assertions give the wrong impression, and that adding pre-load simply raises the rear of the bike.
This is to compensate for the fact that an additional load has already compressed the spring and reduced the ride height. The pre-load adjustment is required to retore a reasonable ride height, to place the suspension piston within the midle area of its range and to prevent the suspension from 'bottoming out'.
The diagrams are my interpretation of what happens to the suspension.
Comments / criticisms welcome - but if you disagree, please explain. I want to understand.
Fig 1 - Weight of bike and rider. No preload. Spring partly compressed, ride height is OK and damper piston is clear of the top and bottom.
Fig 2 - Extra weight is added. Spring compresses. No preload. Suspension is in danger of bottoming out on the damper piston. Ride height needs to be increased.
Fig 3 - On centre stand, Swing arm drops. No weight on suspension. Suspension is at maximum extension.
Fig 4 - Preload is added (red ring). With the suspension at full extension, the lower and upper mounting points cannot be moved further apart. So adding pre-load compresses the spring.
Fig 5 - With pre-load added, bike is removed from centre stand. The load is same as in Fig 2 so the spring compression is the same as Fig 2. (Hook's Law - Same Weight = Same Compression).
Ride height is now OK. Damper piston is clear of top and bottom (as in Fig 1).
Result - ride height is increased, spring compression is the same as before the pre-load was added. (See Fig 2).
If the bike is not put on the centre stand when pre-load is added, what happens is slightly different, but the result is the same:
Fig 1 - Bike and rider, no preload, ride height is OK (as before)
Fig 2 - Extra weight added. Spring compresses. Ride height is now too low.
Fig 5 - Preload is added while the weight is still on the spring. There is no extra weight to compress the spring further and the rear of the bike is now moveable. So the rear rises.
Note that the amount of spring compression is the same as in Fig 2. Also the ride height has been restored to the same 'OK' point as Fig 1 before the load was added.
Following from the comments from SMSW and dduelin later on in this thread:
On some bikes without weight of the rider or pillion, the suspension is at the maximum extent of its travel. (Pic 3)
When pre-load is added the suspension unit cannot extend any further, so the spring compresses. (Pic 4)
The compressed spring is able to support some of the rider's weight without compressing further. The rest of the riders weight causes the spring to compress a little and the entire suspension unit to lower the bike slightly. (Pic 5)
In fact, the total spring compression is identical to what it would be if the weight of the rider was placed directly onto the spring - but in this case, due to the pre-loaded spring, the amount of movement from the suspension unit being 'topped out' is much smaller. When the rider gets off the bike, the suspension is at the very top of its travel. This doesn't happen with the ST1300. When the bike is on its wheels, the weight is supported by the spring which is already beginning to compress.
Whichever way you look at it, providing that the unit doesn't top out or bottom out when riding, if the rider gets off and adds a little more pre-load, all that happens is that the rear of the bike will be a little higher when the rider remounts.
Whichever way you look at it, adding preload compensates for the extra load of rider, pillion and luggage. Increase the laod, you need to add pre-load to the suspension to compress the spring and move the piston somewhere to the middle of its range to prevent it from hitting bottom or hitting top when riding over bumps.
What it doesn't do is make the suspension stiffer. For that, you need to buy different springs.
Over to you ..... !
Over to you ..... !
