- Joined
- Mar 18, 2006
- Messages
- 2,846
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Useful information, and thanks for sharing it, but rather than putting it to bed, it leaves us (me at least) in more doubt. It is at odds with what the chap from Honda UK told me. Post #33. Not that I am saying that the Honda UK response is definitive because he says that the Motul stuff is what they are using. He doesn't say that Honda have told them to use it. He says that is should be OK, not that it is OK.I vote for.....let's dump this can of worms on the floor.
I emailed American Honda about the extinction of M60 grease. Got a real phone call this morning.
1-M77 is the recommended replacement for M60, according to 'engineering'
2-Most any moly grease, assembly lube or paste will work as a sub for the 'intent' of the original M60 suggestion by Honda.....also according to 'engineering'.
3-The important thing is to keep the drive splines lubricated and hard grease removed prior to applying fresh grease.
All this according to Honda engineer, Massi, who phoned me....was hoping for an emailed response I could share. I'm just a messenger this afternoon.
The USA Honda chap does say it is the recommended replacement for M60, but chose to phone rather than send a written reply.
His suggestion that Moly grease is Ok, we assume to be incorrect - the Workshop Manual makes a clear distinction between the use of MoS2 grease and MoS2 paste.
It is difficult to separate fact from opinion, and so far I don't think we have a definitive answer.
I am looking for a paste, NGLI #2 consistency, 40% MoS2 minimum, waterproof, stays put and is approved for use under extreme pressures.
The Dow Corning M77 paste does not meet that last criteria. I'm of the opinion that Dow Corning make the M77 for Honda, but I can't find now why I believe that to be the case. Possibly because I have seen it referred to as Molykote, and that is a Dow Corning trade mark.
One things for certain - I wont be using M77, and I won't be using the Motul stuff either. But I will continue reading up on the suggestions to see if the spec matches.
Does anyone with a later Honda Workshop Manual than mine have any other recommendations for the Moly Paste ? The Info in my manual (A2/A3) is on the page with the symbols, immediately before the section 1 index for General Information.
But from post #1, we seem to have a clear indication that the M77 stuff doesn't stay put, and we know the Dow Corning M77 is suitable for low to moderate pressures - from their spec sheet.
