Bar end weight falls out
STBernard
BlewBayou
Bellevue, WA
2004 ST1300A
8295
My left bar-end weight fell off recently. I thought, easy enough, I will put it back in and tighten the fastener and be done with it. Well, not so, said gravity. I had to tape it on. Looks kinda hokey. Not sure if it matters, but I have the heated grips...
It seems like it should go in farther, but it's all the way and will not tighten (expand?). Any ideas? Would a new one make any difference? Should I wrap the business end with something that may provide more purchase?
002760
Pull it all the way out and show us a picture, it should grab enough on it's own and it also matches up with part of the bar end a certain way so it won't turn.
This is what the throttle side inner bar looks like:
You might have a broken clip:
I had that before and had to replace w/new one:
STBernard
STBernard
BlewBayou
Bellevue, WA
2004 ST1300A
8295
I will do that. It is not the throttle side. And it was very short, maybe 3 or 4 inches long including the weight. I did not recall any clip but will get some pix tomorrow.
Eastern Massachusetts
05 ST 1300 A
7486
Bar end weight removal ?
Can't get them off to install Symtecs..
Any suggestions ? The left weight also is out 3/8" from the grip..It turns 1/4 rotation but won't pull out and the stud does not see, to release whatever is inside the bar.
07 ST-1300
Assuming Joe fixed his broken bar end hardware some time ago, how did he have the foresight to take pics of the individual parts? I thought Larry (Igofar) was the compulsive one....
002760
LOL... I can't compete with Larry's attention to detail.. but I was always taking pictures for the site whenever I did anything to the bike so glad it has been useful.
wjbertrand
Ventura Highway
Ventura, CA
In my experience a tip over, with handle bar end contact, breaks the inner weight right where it necks down behind the retaining clip. I had to use a screw driver to pry the clip out along with the outer rubber bit, then use a long bolt with the correct thread to extract the main part of the weight from the bar.
Well, I bow to your expertise and yield the title of 'Most Experience with Tip-overs'. Luckily, I've not had breakage to anything besides scraping the tip over guards and Bygdawg's T-O guards. Perhaps I've not had handlebar contact? I'm usually so embarrassed that I just want to get the bike upright ASAP.
wjbertrand
Ventura Highway
Ventura, CA
I learned all this when I was knocked off my ST back in 2013 by a blind Porsche driver. The left one broke hitting the ground, but the car hit me from the right, so I figure that's what caused that one to break.
