Mine too. I use HawksHead.
Yes, I was looking at HawksHead when I started to look at dash units.Mine too. I use HawksHead.
from that picture it looks to me like the FOBO unit could interfere with the caliper, is that what hit it?Still, this 90’degree valve stem is too high and it hit something.
I was thinking it looked like the FOBO added to the length of the arm and something tweaked it enough to spin it on its axis.dwalby said:from that picture it looks to me like the FOBO unit could interfere with the caliper, is that what hit it?
Yes, rear tire is normally hotter.@ibike2havefun
Probably not correctly done, but Ill check again. Thank you very much for the detailed response, Im anal/focused like that and appreciate it in return. If not too much trouble, can you show me pictorially how your sensors & stems are configured, please? Next tire change, I plan on getting the T-stems so I dont have to remove the sensor to add air.
I see your rear tire is 10* hotter too. This normal?
Hi-@ibike2havefun
Probably not correctly done, but Ill check again. Thank you very much for the detailed response, I'm anal/focused like that and appreciate it in return. If not too much trouble, can you show me pictorially how your sensors & stems are configured, please?
your previous post was a month ago, tires lose pressure over time regardless of ambient temperature, when was the last time you topped them off?The tire pressure as measured yesterday, which is some 20*F ambient degrees lower than the other older postings in this thread
Note that the tire pressures read some 4 psi lower when the bike is cold (not run in a few days). There does seem to be the start of some uneven tire wear, so I guess that this is due to the 10% less pressure on colder periods of time.
This is news to me, but I guess I have to keep the 42 psi “cold pressure” regardless of the ambient temperature difference. Which means in the colder season, I need to add air to get the 42 psi to compensate for Boyles Law.
No harm in keeping them as close to 42 as possible, but I'd be very surprised if 3psi difference between 39 and 42 is going to affect the way your tires wear, so I wouldn't worry about "protecting the tires".been awhile, and I get what your sayin Dwalby, but I guess the point Im making is that barring leakage - that due to the pressure lost to lowering of the ambient temperature, I still have to maintain the 42 psi to protect the tires.
