ST1100 Timing Belt, Upper Fairing
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
Doing my valves, timing belt and forks this weekend on my 2001 ST11 ABSII. Looking at the Honda service manual, it says to remove the upper fairing to remove the radiator, which is necessary to get at and remove the timing belt cover.
Do I really need to remove the upper fairing? I’ve got the mid and lower removed, but stopped there. TIA!
British Columbia
2021 RE Meteor 350
For the few minutes it takes to remove it, it will make the job that much more accessible and easy. Never tried doing it without full fairing removal, so I can't comment if it is possible.
ReSTored
Mississauga, Ontario
2019 Tracer GT
4463
As per Bush, once you're that far into plastic removal the upper fairing is just a few minutes more. With everything off this gives you a great cleaning opportunity so everything is spic and span before reassembly.
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
It’s good to get naked every once in awhile. I have had the timing belt done twice, once on a 1990 and then again on a 1997 ABSII. I brought the bikes to a dealer with the mid fairing and lower cowl removed. They did not remove the upper.
I have found it beneficial to remove everything and be able to inspect connectors, replace bulbs. In fact when it’s in that state is the best time to replace the headlight bulbs, put in a fresh set and your good for another year or two. ;)
STraymond
Cincinnati Area
'01 ST1100
8700
It may be inappropriate to mention the 'F' word, but you may want to change the Fork oil with the bike as it is....
paulcb
paulcb
Celina, TX
8735
Did the carbs and everything in the V last year.
Things 'look' pretty good under the tupperware, just a bit dirty. On to the valve check, now that the engine is stone cold. Then the TB and then the forks.
If you are going to do a fork oil change, taking the front wheel and forks off will give you better as access to the timing belt area.
do this, even if you're not going to change the fork oil. I expected that you were, but since they're still attached in the picture, I guess its worth mentioning.
While you are in there, you might as well do an @Igofar tweak of the whole bike. Give him a PM and I'm sure he will tell you what to check.
illinois
2000 ST1100
Paul, be sure to give us a detailed picture of the old timing belt as I still have the old 20 year old belt on mine.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
+1 on pulling the forks for the timing belt R&R, Paul. But as we discussed, loosen the bottom fork bolts first. Good luck with the STOC loaner kit for the fork seals.
Dang, wish I lived closer, would be fun to kibitz and hand you the occasional tool while drinking your beer. :cool:
Good Luck, John
paulcb
paulcb
Celina, TX
8735
How many miles on the timing belt Paul?
Hey Dean. About 110k. The old belt looks nearly perfect, with no detectable stretch. Glad to get it done though.
paulcb
paulcb
Celina, TX
8735
Good Luck, John
I wish you were closer too John, would be happy for you to drink my beer! Thanks for the tips on getting the TB cover off. I finally did get it off and then dremeled off the interfering plastic, as you mentioned... went back on much easier. Had 51 teeth between marks, before and after, as you've previously recorded. Shimmed two exhaust valves (cyl #2), the rest were in the middle of the range. Got it all back together and she fired right up. :) Doing the forks tomorrow.
