Pop-Pop
- Joined
- Feb 29, 2020
- Messages
- 2,453
- Age
- 68
- Location
- Pagosa Springs Colorado
- Bike
- 1996 ST 1100
- STOC #
- 9037
It's looking dried out and dirty I wonder what I can use to refresh it a bit? My form of farcle!
it's grey not blackThanks!
I too had good results with this, used straight. I did not mix it with paint thinner. One of the lower cowls in the photo below had just been treated, the other had not. Can you tell which is which?boiled linseed oil
There is no more danger because you treat the plastic with a bit of linseed oil of fire than there was before you did the treatment. The ignition temp of most solid materials is surprisingly high, and this plastic's melting/warping point is much lower than most of them. It never sees high temps. Consider this - many high end firearms' stocks were finished with many many coats of linseed oil over weeks to build up a thick, durable, beautiful finish. How many of them combust when you shoot the shotgun, rifle, whatever?There was a thread a while back where it was suggested that treating the lower cowls with BLO increased the risk of a bike fire since the cowls are near the hot exhaust system. You will have to evaluate for yourself what you think that risk is, and whether you want to take it.
That's what I use on my face shield.I just use the Honda spray on cleaner / polish. It does a great job on all of the gray bits on the ST.
When I see it on sale I buy a few cans and stock up. The one issue I have is that when stored in a cold garage early spring / late fall it is as if the can has lost all pressure before the product inside is used up. Solved this by keeping the can indoors and bringing out just before using it.
So, it makes the black stuff blacker and the clear stuff clearer?That's what I use on my face shield.I just use the Honda spray on cleaner / polish. It does a great job on all of the gray bits on the ST.
I did this once. It worked well, but attracted a lot of dirt/dust.years ago someone on the old forum recommended plain old olive oil like you use for cooking, so I've been using that for about 20 years now. You need to re-apply it periodically depending on how much your bike sits in the sun.
Probably lettuce and cucumbers, too. Linseed oil dries hard*, so it does not remain sticky; olive and other vegetable oils do not harden.I did this once. It worked well, but attracted a lot of dirt/dust.
