Wow! Lucky for sure.Every 1300 I’ve seen wears more on left side(front). Any bike setting issues known?
No - the exact opposite actually. Pressure and temperature goes hand in hand. If you lower the pressure of your tire, the temperature drops. All other things being equal of course...All other things being equal, lower pressure means greater temperature.
I think you have this wrong. If the temperature drops the pressure in your tires will decrease. If the temp increases you tire pressure will increase. Reducing tire pressure will not reduce temperature. Increasing pressure will not increase temp.No - the exact opposite actually. Pressure and temperature goes hand in hand. If you lower the pressure of your tire, the temperature drops. All other things being equal of course...
I agree with you on this, I have a strong feeling the OP's front tire was underinflated and that's also the cause of the weird wobble he is experiencing. ( I have personally experienced the underinflated tire wobble)Under-inflation is one of the leading causes of tire failure. If tire pressure is too low, too much of the tire's surface area touches the road, which increases friction. Increased friction can cause the tires to overheat, which can lead to premature wear,
You're missing the dynamic analysis. A tire with lower starting pressure will get hotter than one with higher starting pressure. Lower pressure means more tire flexing and heat generation. A full tire flexes less, which means less heat gain during riding time.No - the exact opposite actually. Pressure and temperature goes hand in hand. If you lower the pressure of your tire, the temperature drops. All other things being equal of course...
I have replaced tires with 1/3 or more tread left before a long trip quite a few times. It hurts.Well, you've definitely had your monies worth out of that.
I'm glad you noticed it when you did. I won't kick you whilst you're down, enough have done that already.
It's a PITA replacing good tyres before a trip but it's definitely worse if you don't.
Good luck with the replacement.
Upt'North.
Under-inflation is one of the leading causes of tire failure. If tire pressure is too low, too much of the tire's surface area touches the road, which increases friction. Increased friction can cause the tires to overheat, which can lead to premature wear, tread separation and blowouts.
One of the reasons I bought tire changing tools last year was so that I could remove a perfectly serviceable tire with decent life left before a trip, and then potentially re-install it later (the economics of having a shop reinstall an older tire simply don’t work). I haven’t done that yet, and may never do it, but it will make me feel better about removing a tire early.
You guys [...] should have a second pair of wheels.
Don't dismount and remount tires, just swap wheels.
I'd have thought many mile before right now.1- Your tire is dead, and need to be replace right now.
You are missing the "all other things being equal"...dynamic analysis adds a lot of other things...You're missing the dynamic analysis. A tire with lower starting pressure will get hotter than one with higher starting pressure. Lower pressure means more tire flexing and heat generation. A full tire flexes less, which means less heat gain during riding time.
Your are adding a lot of other things, and the statement clearly says "all other things being equal". I am simply saying that if you let air out of your tire at standstill, the temperature will drop (and vice versa). We all understand that riding with a low tire adds more friction which generates heat, and hence increases pressure. This is the main reason you start with low tire pressure whenever you are riding on a race track. The aggressive riding will heat up the tire more than normal, so you need a lower starting point to arrive at the "correct" or ideal riding pressureI think you have this wrong. If the temperature drops the pressure in your tires will decrease. If the temp increases you tire pressure will increase. Reducing tire pressure will not reduce temperature. Increasing pressure will not increase temp.
I just noticed it, after days of hard riding (and having a blast!). My front tire is showing broken steel cords and it’s 7pm Saturday at Sturgis SD. I was going to post tonight to ask about an odd wobble I get when hands-off, but I may know. I cannot safely ride, live in Washington. Any ideas?
