STmark1300
Ron
I added a 10 guage direct connector to the battery with no fuse. Then I began thinking it may fry my electronics. Is this safe for jumping a dead battery. The trickle charge connector is still there
Jumping — maybe if your bike is in a good state of tune. The high current draw would be only for a few seconds especially if that 10ga wire is short.Is this safe for jumping a dead battery.
Hi Larry:I prefer a portable jumper to cables. They're smaller, lighter, faster, serve other uses, and you don't need a second vehicle.
I got this one from Costco a few years ago for $10 less than the one below. It still hods a charge, and I started a Grand Cherokee for a lady one evening. The case size is 3.03 x 1.06 x 6.61 inches.But how heavy is a portable power source? How much cubic space does it take up compared to a set of motorcycle jumper cables? And how often do you have to recharge it to keep it fully charged? Does it eventually time-expire (meaning, not accept a full charge anymore)?
I'm sure you have seen these, Michael. The Lithium ion batteries are quite small, and a lot of guys are carrying them now. Larry posted a pic of his...But how heavy is a portable power source?
You need to remove the seats, and a side panel.Isn't it a bit too much, when, if you need to boost your ST, all you have to do is remove the seat, two screws and the side panel, to have full access to the battery ?
Unless it is more complicated on the ST1300?
Isn't it a bit too much (installing a jumping/boosting cables & connectors), when, if you need to boost your ST, all you have to do is remove the seat, two screws and the side panel, to have full access to the battery ?
I can understand it for a quick access connector for the batterry tender, but... you shouldn't need to boost your batterry too often, unless it's time to replace it.
The trouble with the ST1300 is you need to have two keys. Once you have the bike jump started you're not going to want to turn off the engine and remove the key so you can re-fit the saddle bag and seat.
Another reason for easy jumping posts.The trouble with the ST1300 is you need to have two keys. Once you have the bike jump started you're not going to want to turn off the engine and remove the key so you can re-fit the saddle bag and seat.
With the ST1100, you can put the parts back in place (side panel, left pannier and seat) without needing the key.
