Jambriwal
2016 ST1300PA
When i first got the ST 11/20 it had a pull to the right. After reading the correct front axle tightening procedure here it eliminated most of it. Decided to recheck after reading Igofar post on axle alignment. Sure enough factory assembly was close but not right. See pic. Removed fender, loosened axle, pinch bolts and brake bolts. Then loosened lower pinch bolts on Right fork leg and finnaly upper pinch bolt. Now axle slides back and forth with very little resistance.
Thanks Igofar.
No more pull to right.
Thanks Igofar.
