Here are links to posts in our forum that explain how to do the above:Yup, you need probably need to service your pre-load adjuster, correct your preload and damping settings, and get a better tire pressure gauge.
IIRC, the first time I did the preload refill it took a couple of hours. Get your mineral oil and hypodermic fork oil filler ready, and go ahead with this service. When you pull the knob off the preload adjuster be careful not to loose the little ball bearing and spring that give you the detents. I spread an old sheet on the floor around the bike to grab that steel ball when I drop it.Both are fairly easy tasks, although the preload fluid replenishment will take you a few hours of work if you have not done it before. Best to do that job inside a heated, well-lit garage where you can leave the bike overnight if the job is only half-finished and you want to finish it the next day.
Much 2-up?I've never tried Michelins on my ST, and never seen that type of wear on any Bridgestone's rears.
I normally wear the rear out till it's bald and change it out.
Also, never touched the Preload or rebound adjuster since I bought it in 2009.
All 2 up and also with a uni-go trailer for a few years.Much 2-up?
As you've brought it up, inquiring minds would like to know what the ST Whisperer recommends for a tire pressure gauge?and get a better tire pressure gauge.
I always run my Bridgestones spot on 42 psi. Seen them rise as high as 52 psi when it was 103 F out doing 85 MPHI'm on T31 GTs. I like Bridgestone tires, generally. What pressure do you run?
Intercomp 360067 $50As you've brought it up, inquiring minds would like to know what the ST Whisperer recommends for a tire pressure gauge?
Thank you kind Sir!Intercomp 360067 $50
Longacre 53036 $45
Motion Pro Digital Tire Pressure Gauge 0-60 $88
Most tuners would have about 35 to 40 mm sag with the bike loaded with rider(s) and normal stuff carried in the bags. If the preload adjuster is in good shape it isn't difficult to get sag in this range by cranking in a lot of preload but when sag is measured with rider(s) off the bike, static sag, will be close to zero. This indicates the spring is much too soft. The result is the bike will be hitting the shock's bump stop often when loaded to normal riding weight and going down the road. Of course the bike can be ridden like this and we get used to the way it is. Every time I've done a suspension upgrade I'm reminded that until I get better suspension the suspension I had was good enough. We also have to remember that because both front and rear is undersprung, upgrading just one end or the other can make handling worse by raising the ride height and changing the steering geometry. With stock suspension the ST1300 does respond well to lots of shock preload with improvements to ride and to handling.Did the preload adjuster at the beginning of the season. Have actually been running this year with more preload than I have in the past. Taller for my short legs to manuever but it seems to handle better. How much sag are we supposed to have? Haven't done anything with the rebound damper. Suppose I need to have a look at that.
That's the thing. Both ends are really soft. Under my geared up wt. of 165 lbs the forks had 47 mm of rider sag (44% of travel). I added fork preload to a target sag of 36 mm (33%) which slowed the steering geometry quite a bit. If I left the shock at the recommended 7 clicks the sag and resultant steering geometry was much slower than designed and I liked because the rear end was sagging so low. The bike ran wide in corner exits so I raised the fork tubes in the triple clamp as much as I could and ran about 30 mm of rear sag (24 %, or less than optimal) to sharpen the steering.Doing one end of the other should be ok unless one end is much softer than the other.
