Here is the new Antigravity battery installed.
This is really interesting:
ATX12-HD-RS
ST1300:
Capacity: 16AH Pb equiv / 8 actual (?)
CA: 480 (not listed as CCA)
The ATX12-HD compatible 12 different OEM bike battery sizes (Li cells easy to configure for size) and built-in BMS. Impressive – maybe not unique.
BUT WAIT – there more!
These batteries have four – count 'em –
FOUR battery terminals. Not only is orientation/positioning not a problem — you have two terminals left over for wiring farkles. Awesome.
BUT WAIT – there's still more!
This has what A-G calls built-in
jump starting.
The revolutionary ATX12-HD-RS RE-START Battery intelligently monitors its status, and just before going completely dead puts itself to sleep with just enough energy to get your vehicle start again. Simply press the RE-START button located on the battery, start your vehicle and drive away…
Sears Die Hard batteries once had something similar. IIRC there was a "reserve" section that with a flip of a switch on the battery allowed that to start the car. But I believe that was at the expense of maximum battery capacity.
There have been a couple of third-party add-ons that do the same thing as the A-G Re-Start — shutting down the battery at a give voltage to save enough to start a car.
There's a remote available so you don't have to access the battery proper to press the Re-Start button.
I know — there's 50 ways to start your motor without all this gee-gas tech and that ain't what grandpappy would do — he'd spin in his grave first. But this ain't my grandpappy's ST so my next battery might just be this A-G.
And jumper cables are cheaper but if you don't have a buddy with you that day — who wants to stand next to your ride with cables in had begging "Please sir - may I have some Amps?"
Downside — an Li specific charger is a must. But this could be the last battery I'll ever buy.
Mike – way to
omit bury the lede.
(The devil is in the pics.)
