Pics of Moby
Ryan_B
Denton, TX
2016 Honda ST1300PA
Did you add the red/orange stripe on the rear wheel? Or is that a protector of some sort? The all white bikes are pretty.
Ryan
Wow even your rotor spools look clean :rofl1:
Nice looking bike.
Beeflips
(it's me...Greg) Returning some videotapes
Portage,(Kalamazoo) Michigan
2000 ST1100Y
I really like this ride
Liking the running lights, fills in under the high beam, and toward the sides of low beam, they are fog lights as well, but have yet to hook up that part20220730_071621.jpg20220730_071611.jpg20220730_071600.jpg
I agree with the others about the white. I really like it. I'm tempted to paint my 1100 this coming winter. And I'm planning on sticking to stock Honda colors just in case replacement parts are needed.
RichKat
Rhome Texas
2011 ST_1300 PA
9102
Finally got around to hooking up the yellow fog function of these light, have them wired to the 1-2-3 switch, position 1 is yellow fog, position 2 is white running. Thanks again Nexus for posting the switch wiring photo
Willsmotorcycle
Ride more...
Makefield Highlands PA
2016 ST1300P
003726
Unless I'm wildly mistaken, you may have to switch that 1,2 combo. I have the Zmoon and if the yellow are powered there is no white. Switch 2 works with switch 1, if you flip your wires, 1 is white, 2 is yellow, that should solve the Zmoon wiring. IIRC...
RichKat
Rhome Texas
2011 ST_1300 PA
9102
Wiring diagram for these shows, they are yellow only, white only, and power to both is white also. Shows them hooked to low headlight for yellow, high headlight for white
For a couple dollars, you can go to autozone and pick up a couple small amber running lights (above the headlights).
They are a direct plug and play, and they are very visible.
Northern Baltimore suburbs
ST-1300A '09/'12
000298
No prob!
Oooohhh! Is that an OEM top case? How'd you pull that one off? They are notoriously rare!
