Brake Pad Reference: ST1100A ABS II
New England
1999 Honda ST1100
Hi everyone!
I'm new to my 1999 ST1100, which already has 132k miles on it (US). Runs beautifully, and I love it. The only problem I have run into is that NONE of the workshops near me want to touch this bike. They all say it's too complicated. I did convince one to change the rear tire, and they sourced some brake pads for me, which ended up being the wrong ones, so I have now done a lot of online reading and wanted to summarize it for all people who come after me looking for this information.
Important things to know:
  • The ABS II brake pad size is physically larger than the ABS I brake pad and the non-ABS pad. It is easy to mistakenly purchase the ABS I brake pad because clear information is not out there. (I have a set that I'm willing to sell!)
  • The ST1100 has a number of sub-models, which you can find on the front fork along with the VIN. In my case, it is the 1999 ST1100 A, with ABS II. In various websites, this is written as ST1100A A, ST1100A ABSII, ST1100A AC, ST1100AA, etc. The "C" in "AC" seems to stand for "California", which is mostly the same bike with different jets for CARB emissions compliance. There may be other differences that I do not know.
  • On the ST1100A ABSII, the front and rear brake pads are NEARLY identical, but they are NOT identical. The rear pad has an extra groove on the periphery and is thicker to start. You can use a worn down rear pad on the front, and you can file the groove into the front pad to use on the rear. But they are NOT the same. Shops will tell you they are, but that's not technically correct. They are similar.
  • The ST1100A ABSII has THREE calipers: two on the front and one on the rear. You need THREE SETS of brake pads to do a full replacement.
  • ONLY USE OEM PADS. Non-OEM pads may be "harder" or may wear less, or may have "extra friction" but all of this comes at the cost of changed riding characteristics, questionable wet performance, and INCREASED ROTOR WEAR. OEM Pads are cheaper than a rotor.
OEM Part Numbers:
  • Front: 06455-MAJ-G41 (you need TWO sets)
  • Rear: 06435-MAJ-G41 (you need ONE set)
  • Alternatively, you can use THREE sets of the FRONT pad and grind the groove in (see the Credits section).
Where do I find them? (Rhetorical Question, Here's a reference of a collection of places recommended on relevant threads in no particular order.)
Credit where credit's due:
Uncle Phil
4 ST1100(s)
006717
698
I usually use RonAyers.com for my brake pads for my ABSIIs as they usually have really good service.
'Too complicated' is a joke when you compare modern Hondas to a ST1100 - even the ABSII ones.
The problem is that most of their techs aren't old enough to have worked on ST1100s so it won't be quick work for them.
They might have to actually read and figure something out. ;)
Smudgemo
Intermodal Man of Mystery
Berkeley, CA
'08 GS / '78 CB550
I'm unclear on the question. Where to find them? Any of those places that sells OEM parts will work.
I think I'd make every effort to source the correct pads for each end, but that's just me.
New England
1999 Honda ST1100
I know! I mean, this is basically a simple bike compared to what's on the market today, it doesn't even have a radio! But that was literally the response I got from ALL 3 local shops (and by "local" I mean half an hour's drive in different directions), including a Honda dealer. The dealer told me they don't work on anything more than 3-5 years old.
British Columbia
2021 RE Meteor 350
Another reason they often refuse to work on older bikes is that they are responsible for whatever work they do to make the machine roadworthy. That means if they find something that needs attention and bring it to the owner's attention, they can often face refusal to do the extra work, which leaves the dealer in a potentially legal bind about that responsibility, should something dangerous be left unattended.
New England
1999 Honda ST1100
Yup. I'll order fronts and rears separately if they're available. Also, it was a rhetorical question; I've edited the post to be clearer.
New England
1999 Honda ST1100
Yeah, well, that's just the insurance man getting in the way of getting things done. :(
Ron
Orlando
ST1100s
2432
... They all say it's too complicated. ...
I was told, a lot of the time, the tech doesn't have the training to work on the older bike. Also, it would be easy to have the bill more than the value of the bike.
British Columbia
2021 RE Meteor 350
Well, that has to be the lamest excuse I've heard! Doesn't have the training to work on older bikes?? *****. If the kid can strip and rebuild what's selling as new now, an old ST couldn't be any easier. Except maybe carb work. :rolleyes:
