bHi. When turning my ignition key the lights on the panel all come on . If I move the key a fraction then the lights go off. Engbutbutbutine cut out on a b. But
BBut
But moving the key
BBut
But moving the key
Ignition switch. I disconnected the connector block and the red wire came adrift from somewhere. I was thinking of starting the bike up and see what doesn't work..Could you send a picture of where the wire came loose? Are you talking about the ignition switch or the Ignition relay?
I stripped the ignition key assembly , cleaned and greased the contacts. Put it all back together and the key now works fine. Just my loose red cable?From the OP's stuttering first post, it sounds like an ignition switch gone bad, at first, but then the loose wire issue comes up. The switch contacts will wear over time, causing that exact problem of lights all going off, or on, with a tiny movement of the key.
Some clarification and pics would help.
Thanks. The bike is ex police 2002. I wonder if it could be an auxiliary wire to?? I intend to start the bike and see what doesn't work. If no joy, then I will remove the air filter complete and take photos. Thanks againHave a look at the 1100 wiring schematic in the Honda service manual and see if there is a red wire in the area of that connector. Failing having a picture, we are just guessing what you are seeing. I no longer have the manual to check this out.
