Nothing to add to what has been said already - except some points of information.
1. The master cylinder on the right hand side behind the large silver alloy footpeg bracket is the master cylinder for the brake pedal. It is not the SMC.
2. The slide pin that is shown cross threaded in Larry's post #22 - the one that should never be undone unless it is being replaced. This is the main caliper slide pin mounted on the caliper itself. The early service manuals (including the illegally copied version that can be found online, and my 2004 version) have diagrams that confuse this part with a different part. It is labelled as having a torque setting of 69Nm.
This is wrong. That torque will strip the threads out of the caliper. The actual torque value is 27Nm ***
(The part that it is confused with is the caliper bracket stopper bolt - which is not shown in the caliper bracket exploded diagrams. You will find that on the swing arm fiche, and that does have a torque of 69Nm. You can't confuse the two except in a diagram - the stopper bolt is a seriously big lump of metal! )
3. The silver retainer clip that fits onto the caliper bracket to locate the tab end of the brake pads:
Note that the rear retainer clip has a ridge, the front retainer clip does not. Get them the wrong way round with OEM pads, your front brakes will not release properly and your rear brake will drag as a result. Also, this clip should be glued in place.
Honda recommend a Threebond 1521 adhesive to fix this retainer in place. It is a flexible adhesive which I believe is required - not to hold it in place, as it can't go anywhere - but to prevent vibration wear of the recess in which it seats in the caliper bracket. A worn recess results in pads sitting incorrectly.
I found a UHU Extreme Repair adhesive which has similar properties to the three bond, and is more readily available in the UK.
The requirement for glue is mentioned only in one place that I have found - Section 1 general information - towards the end of the table that shows lubrication and seal points.
Torque values can be found in a number of places in the workshop manual.
- On the diagram
- In the text of the manual
- In the list at the start of each chapter
- In the torque settings at the front of the manual, section 1
The torque setting table in section 1 also shows the thread sizes.
To find the correct name of a part, use online parts fiches to help identify the image, and look for the number in the table. What is listed is the name that Honda uses.
First time you lookup a torque setting, make sure that all 4 places quote the same value. sometimes the process of labelling diagrams and adding detail to the text introduces errors.
