Hi Guys.
I've owned a coupe of non ABS ST1100's and a familiar with a tool kit. Swapping brake pistons / calipers / hoses a fluids not an issue on that bike.
I recently purchased a 2002 Non ABS ST1300 with 31,000 miles on it. A few days later a realised when the bike on centre stand the rear wheel wouldn't freely rotate, I could turn it by hand but there was no rotation without me physically pushing it.
So, I did my ST1100 thing. Removed the rear calliper, pushed out the brake pistons, cleaned and lubricated them, then pushed them back in, using a G clamp and wood combination. This improved the situation a little, as the wheel does rotate a bit.
Since then I have removed the front callipers, cleaned up and lubricated the pistons. The right ( when sat on it ) hand calliper had seized on the sliders, but that was also sorted, and now slides easily.
I then performed a brake fluid flush, following GTs Garage technique : - Bleeding Linked-Brakes (ST1300a) Step by Step - YouTube
So, how much brake drag is normal ?? I've tried to attach a video but it won't accept MP4 formats. " https://youtube.com/shorts/h82GJu64A7s?feature=share "
Or does this indicate a problem with the SMC or proportional control valve ?
Thanks in advance
Thanks in advance
