This ^. An LED compatible flasher relay will sort it. I put one in my car and one on my bike when I switched the turn signal bulbs to LEDs. LED bulbs don't draw enough current to make the factory flasher work properly. Some people do like the "hyper-flash".You want a 2 pin flasher for LED.
I liked to add that when you pull the OEM flasher it has three (3) pins (pa model), ignore it and just plug in the new one like OBO, it will work.
Does anyone know what the third pin is for?
I tried to follow it on the schematic once, maybe the glasses weren't working that day, tried again. I think it goes to the option plug (quartet). My wired turn signals flash with out the 3rd wire on the flasher. shrugs shoulders emojiIf I was to guess I'd say the 3rd pin on a PA is a power feed running to the PA hand gear so you could have 4 ways on when the bike is off? That would require a flasher with more than 2 pins though, or a jumper wire.... I also don't know how the PA uses the 2nd battery (separate, isolated or in parallel.)
thank you so much bro
You want a 2 pin flasher for LED. They are sold a variety of places and prices. Just make sure it has that connector on it so it will be plug and play.
Thanks for the guide, very helpful help, I've got it installed. Thank you so muchI didn't cut the mounting tab off mine and it fit in the space without issue. I think I moved the rubber "elastic" over and mounted it like these photos.
If I get around to it I'll open it up and snap a photo of mine. If I didn't mount like this then I tucked it in the small space. It won't go anywhere.
View attachment 309235View attachment 309236View attachment 309237
