Article [13] ST1300 - Quartet Harness Farkle Wiring Guide
Allenton Michigan
2012 ST1300
Eastern Beaver makes a harness with two plugs. One is switched the other is unswitched. Comes with connectors and pins to complete the cable for $19.95
Ampthill
Great article, thank you. I have just connected a USB and sat nav to my ST1300. While checking the voltage on the switched accessory leads I blew the 15amp fuse. It took me some time to find it at the side of the front fuse box, see pic. I also found connectors on ebay that fit the black and red sockets. Good to have all the fairings back in place, great result.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
An old thread, I know - but it contains some incomplete information: I posted this a few years back in another thread, but it may also be useful here - especially since @TonyST in the last post ened up blowing a 15A. fuse!
The quartet harness doesn't draw all of its power from one 15A fuse. It is supplied with power from three different fuses, all of which are already used by other components, but each of which has some spare capacity.
Different versions of ST1300 have different fuse boxes, but I've quoted the label on the fuse box lid which will help to identify which fuse is which. This is from a UK 2009 Abs model. Your model may vary, but it may help you to check out what capacity your model has.
Note that you must never increase capacity by fitting larger fuses ! The fuse is there to protect the wiring and connectors which are not designed to carry greater currents.
'Pass' mentioned on the white connector, is a function of the headlight dip switch on Uk bikes. In dipped mode, the main beam / dipped beam rocker switch has a third position - a spring loaded action to allow the flashing of the main beam while the dipped beam remains on.
Isle of Man
'02 ST1300A
Hi TonyST
Any chance of posting a link to the eBay site you got the connectors from please?
I've just managed to get some heated grips and a Sat Nav, as well as the Quartet Harness for my '02, so I've some work ahead to wire everything up.
All help appreciated.
jfheath
John Heath
2013 ST1300 A9
000679
2570
Hi TonyST
2.8mm Honda Suzuki Kawasaki MTW Mini-Latch Wiring Loom Connector (kojaycat.co.uk)
If you get a 9 pin connector, you can make your own harness with leads the length that you need - rather than squashing everything by the headstock.
I like to buy the terminals with for larger wires if I can. If they are too big, you can snip them off before crimping. If they are too small, they do not crimp and have to be soldered. They must have the latching / locking mechanism.
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
Hi TonyST
I found a box of male and female mixed connectors from Amazon, and others have bought the same kit.
One example of several:
https://www.amazon.com/Glarks-Electrical-Automotive-Connector-Motorcycle/dp/B07Y4QFF92/ref=sw_img_d_crh_rh_top_sim_0?_encoding=UTF8&pd_rd_i=B07Y4QFF92&pd_rd_w=57xYE&content-id=amzn1.sym.f955a421-f296-47b8-98f4-e33d21582bdb&pf_rd_p=f955a421-f296-47b8-98f4-e33d21582bdb&pf_rd_r=Q7ZPBXMEKQXREGXK3KD1&pd_rd_wg=7Addg&pd_rd_r=ae41bf45-d545-46cb-9b5c-b05f46649390&th=1
Isle of Man
'02 ST1300A
That's great!
Thanks for the info. :slvr11:
Willsmotorcycle
Ride more...
Makefield Highlands PA
2016 ST1300P
003726
Small business, quality kit.
Josh_ST
I love my 2 wheeled therapy machine!
Marysville, OH
2003 Honda ST1300
000237
Isle of Man
'02 ST1300A
Thanks!
london
I need to change the very thin cable from my ACC socket to the quartet harness. does anyone have some suggestions for decent 2 wire connetors that will last maybe the type that have a rubber seal? The standard connectors are not great so i intend to remove the 9 pin plug and rubber boot and cut the cable out i will then add 3 new 2 wire connectors to replace the red white and black ones. Then i was thinking to wrap it all in self amalgamating tape. Should i add anything over the top as a extra layer of protection?
Willsmotorcycle
Ride more...
2016 ST1300P
003726
Just a thought, if you don’t like the connectors, solder the wires together and heat shrink tube, you’ll never have another failure there. Otherwise, they are Hitachi connectors, available at many online retailers, don’t forget the crimper.
Mesa, AZ
VFR750F, ST1300
Also when crimping anything, don't use generic terminals and crimpers you find at auto-parts stores. They just crush terminal into crescent-shape, but don't squeeze OD inwards and increase contact surface area. End up with insufficient contact between wires and outside terminal. Resulting in higher resistance and heat. Gets worse over time with corrosion. You'll end up with burnt terminals, connectors and broken wires.
Best to use factory OEM connector & terminals. Most are Sumitomo with some Yazaki.
https://www.corsa-technic.com
https://www.bmotorsports.com/shop/index.php/cPath/109
https://www.easternbeaver.com
https://www.ksvlooms.com/collections/all-items
https://motorcycleconnectors.com
https://cycleterminal.com
https://www.automotiveconnectors.com/connectors-and-accessories.html
https://www.efihardware.com/products/c293/Connectors
http://www.vintageconnections.com/
https://kojaycat.co.uk/
https://www.3waycomponents.co.uk
Crimped terminals should look like this. Notice 2nd crimp over insulation for strain-relief. Get matching crimping-dies for particular terminals you're using. It will do both crimps at once to optimum pressure. I prefer TE/AMP Ergocrimp line of crimpers and dies.
Then replace air between wire-strands at crimp with solder for much improved conductivity (lower heat) along with sealing wire-ends from moisture creeping down and causing green/black wire-disease.
credit: http://www.cycleterminal.com/crimp-tools.html
Mesa, AZ
VFR750F, ST1300
Yup, best to join wires with proper linesman/western-union knot with solder and adhesive heat-shrink tubing. Maintaining consistent diameter across joint is key to reducing stress-risers and fatigue damage over time. It's done this way in pro-motorsports (F1/MotoGP), military and aerospace applications for performance, reliability and durability. No need to pre-tin on larger stranded wires, makes it too difficult to tie knot.
Link to NASA STD-8739.4a.pdf
Here's ultimate solution to burnt connector between stator & RR on many VFRs and CBRs.
london
Thank you everyone. The normal connectors are bigger than they need to be and i dont need the 9 pin. I know by the quantity of cables coming out the bike certain cables are split and some are extra. so i dont need the turn signal wires or the constant 12v feed which is split to 2 so thats 4 cables to remove. I have a pin removal tool so will remove them from the 9 pin connecter plugged in at the loom and seal the holes. I was looking at something like these connectors in the picture. That said the idea of soldering the quartet direct to the items is appealing but makes changing or adding items harder in the future. It would depend on the size of the connectors shown if they are very bulky then solder direct maybe the way forward instead. I prefer decent soldering to crimping despite crimping being quicker. I could just go with 4x 2 pin plugs
Willsmotorcycle
Ride more...
2016 ST1300P
003726
Not positive these are the same as your picture, here is a two pin like your picture with the 9 pin and 2 pin. Shown with the international size gauge.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Yeah, you had to make this repair on the V45 & V65 Sabres.
