Torque For 40 AMP Alternator - 3 bolts 12mm Head
Uncle Phil
4 ST1100(s)
006717
698
I can't seem to find a torque setting for the 3 12mm headed bolts that secure the alternator to the engine in the Honda Service manual.
It gives a torque for the nut that holds the wire in place but I see nothing for the 3 mounting bolts.
Any ideas?
British Columbia
2021 RE Meteor 350
I'm not 100% certain, but if memory serves, as I no longer have the manual (maybe it was Clymer) where I found it, it was 45 ft/lb. John O. will know for sure. Hopefully he will be along shortly.
Phil, @Bush's number seems awfully high to me. Torque goes by the bolt diameter - not its head size or style.
You said a "12mm headed bolt". Do you mean the bolt is 12mm or the head is 12 mm? I pulled out my 12mm wrench and a plastic box of assorted nuts and bolts. I had none that fit the wrench, but an 8mm bolt came close. An 8mm bolt takes 16 lb ft of torque. My HSM says a 12 mm bolt gets 40 lb ft. Note the page shot below is from my 1300 manual, '03-2011 edition.
Uncle Phil
Uncle Phil
4 ST1100(s)
006717
698
12mm is the head size not the bolt size, as I said '12mm headed bolt'.
45 lbs would about right for a 12mm bolt but that is not this size - my ST1100 parts guide says it is an 8mm bolt.
The 'default' torque is 16 foot-pounds so I guess that's about as good as it's going to get.
The Honda service manual (AFAIK) is silent on the torque setting specifically for those bolts (number 4 in the diagram - that's the reason I'm asking) -
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Page 1-15, Honda Service Manual: 20 ft lbs. BTDTx8. Are you positive that flange bolt takes a 12mm socket (not 10mm)?
No sealant on the gasket, assuming new gasket/clean and flat surfaces.
Uncle Phil
Uncle Phil
4 ST1100(s)
006717
698
John - Is that the 'general' Honda Service Manual or the ST1100 Service Manual?
Here's what my ST1100 manual (issued 1996) shows on 1-15
The 'torques' are few pages further along and it only gives the 'general' settings for the bolt size but not for the specific alternator bolts.
It does give the torques settings for three other alternator fasteners but not the mounting bolts which sort seems strange to me.
Uncle Phil
Uncle Phil
4 ST1100(s)
006717
698
John - My guess is that the one I have is 'later' addition as those torques show up on 1-17.
I see specfic torques in mine for -
Alternator Terminal Nut (After 95)
Alternator Shaft Nut
Alternator Drive Gear Bolt
but nothing specifically for the alternator mounting bolts.
In the 'general' section I see 20 f/p for a 8mm flange bolt - is that what you are talking about?
