Measurements need of shock ends
Alabama
Hello everyone I’m needing some measurements of the shock ends and was wondering if anyone had their old shock laying around that would measure it for me. The reason is, I own a Kawasaki Vulcan 2000 and was trying to buy a progressive RAP shock but they are not making them anymore and everwhere I called there out of stock. So after hours of digging around I found out that the Vulcan and st1300 share almost identical measurements and looking at online pictures have the same looking ends. Progressive will not give the measurements out so I turned to y’all for help. If possible I need the bolt diameter too.
vulcan in yellow and st1300 in blue
W0QNX
Blacksheep Tribal Member
Pensacola, FL. USA
06/ST1300 19/R1250RT
007437
Top, your outside, the rubber bushing sleeve is 28.32mm wide and has a 10mm bolt.
Bottom, your inside, is 39.37 wide and takes a 10mm bolt. It's also 20.83 from saddle bottom to bolt side (saddle depth). that would be 25.83 to bolt centerline.
Alabama
Perfect just what I was looking for
