Tried searching to no avail...
Can a, say 1993 swingarm go on a 1998 abs bike? any difference in them?
Many thanks
Many thanks
I'd say you'll miss some mounting tabs for the ABS plumbing...Can a, say 1993 swingarm go on a 1998 abs bike? any difference in them?
yes. was thinking that's the only difference. rubber pad and a tie wrap will do.I'd say you'll miss some mounting tabs for the ABS plumbing...
If you can refab those (reliable and in a way you'll pass a tech inspection)...
Some tabs are spot welded, some clips (on the cross member) fixed with M6 bolts at factory.yes. was thinking that's the only difference. rubber pad and a tie wrap will do.
Not so sure if drilling and tapping holes is a good idea
