I'm going to rebuild all of the brakes calipers and masters and have an extra clutch master kit and was wondering if they are the same parts?
They look the same to me.
Thank you,
Matt
Thank you,
Matt
The clutch master cylinder rebuild kit carries a different part number 22886-MCS-G01 than the front brake master rebuild kit 45530-MAJ-G41 does. The latter includes MAJ in the P/N which indicates it is a part used in other Honda products but the clutch P/N is unique to the ST1300.I'm going to rebuild all of the brakes calipers and masters and have an extra clutch master kit and was wondering if they are the same parts?
Thank you,
Matt
PISTON SET, MASTER Clutch Master Cylinder Kit
22886-MCS-G01
Retail Price: $64.61
Your Price: $49.76
PISTON SET, FR. MASTER CYLINDER Front Brake Master Cylinder Kit
45530-MAJ-G41
Retail Price: $55.25
Your Price: $42.55
MASTER CYLINDER SUB-ASSY., RR. The Rear Brake Master Cylinder Kit has to be ordered in parts
43510-MCS-G02
Retail Price: $179.46
Your Price: $138.18
Just a question, if your having brake issues, have you inspected your Secondary Master Cylinder assembly as well? or checked the condition of your rear caliper mounting bracket?
This may help you2005 Honda ST1300 A OEM Parts, Ron Ayers
Shop our large selection of 2005 Honda ST1300 A OEM Parts, original equipment manufacturer parts and more online or call at 252-758-3084www.ronayers.com
Make sure that the leak is coming from the round weep hole and not from the square drain hole. The square drain hole is the exit of a drain channel that goes all the way to the top of the V between the cylinder banks and can show coolant weeping from hose joints up above the block and because of its proximity to the round weep hole, it can disguise weeps, seeps, and leaks from other cooling hoses that aren’t actually coming from the water pump. I’m sure you probably know this, but if you don’t, it’s worth cleaning the right side in the front of the engine very well and then riding the bike for a while monitoring the coolant that does appear. If you’re not losing much coolant from the overflow tank, you’d be able to do this for quite a while before you ever really needed to add coolant. Not that you should ignore a fluid leak but instead to diagnose its source.Thanks for the info, on another problem. What part do I need to replace if I am getting coolent leaking out of the waterpump weep hole on the side of the of the engine? Is that just the seal or do I need a pump. I've never seen a waterpump quite like this one.
This may have been mentioned already....Check the long hose that runs back to the overflow tank.Yes, it is the square one, good. I found one of the hoses leaking on the thermostat housing and fixed that but I can still smell it all the time. I do not loose much coolant at all and maybe need to add some every 3000 miles but I want to fix it, if I can find it.
