Honda st1100a ignition
British Columbia
2021 RE Meteor 350
As expected (and mentioned previously), those are the early version, which 8mm head sheared off at a rated torque (same type used in cars BTW)...
You'll need to drill the heads off to get the lock out...
That begs the question as to why a 2002 model would have those sheared bolts?
British Columbia
2021 RE Meteor 350
Going out on a limb here to see if this idea might help the OP, without him having to go drilling in there.
Get a can of brake cleaner, one with the fine tube for attaching to the nozzle and insert that into the lock, to help contain the spray within the lock. COVER any painted surfaces above and below the triple tree where brake cleaner could run/splash out. (Hoping it will run out somewhere, of course.)
You have put oil in there already, which is bad for locks to begin with, as it just attracts dirt. Powdered graphite is what you want to lube locks with.
If that works to flush out any crud, the brake cleaner will eventually evaporate with no residue and it may free up the lock. If so, once a day or so has passed, lube with some graphite.
Good luck with whatever route you have to take to correct the issue.
ChriSTian_64
Deux-Montagnes, Quebec, Canada
2000 ST1100Y
9063
Yeah... instead of oil and wd-40, I would try with a good penetrating lubricant, like "loose nut" or any other... but a product specialy made to penetrate between two sticken parts. And leave the product enough time to do its job, that is a few hours. And then reaply and let it alone again for a while. Repeat as many time as necessary. And... dont break the key inside the switch... meaning, if it is still jammed, dont insist too much. Be gentle with the key.
And also... I have to ask : are you sure you have the good key ? Because it is the first time I hear someone with this kind of issue.
Mesa, AZ
VFR750F, ST1300
It’s also possibility that you’ve got worn-out key. Wafers aren’t being moved enough to allow lock cylinder to turn.
Search on here on how to find key-code and get brand-new keys cut (not pre-worn copies). Safer and less money spent compared to breaking key in lock and having to buy new ignition and replacing other matching locks.
Mesa, AZ
VFR750F, ST1300
Also if you must replace ignition-switch, best to remove entire upper fork clamp so you can flip it upside down and hold firmly in vise. Then it’s much much easier to grind and remove security bolts. Replace with regular allen socket-cap screws.
No thief is going to waste time with those bolts. They’ll just pick up bike and toss into back of van. Those bolts just hinder legitimate owners from working on their own bikes.
Did exactly that during the refurb of the '94 ST (installed a full new lock-set, they were in real bad shape since the PO left it parked outside all year round), drilled the heads off, easy to unscrew the stubs after that; but I received and used new snap-off bolts that came with the original P/N... it's not like I need to access this like twice a year ;)
Council Bluffs IA
I have an O5 1300. On page 15-9 there are two special bolts on the handlebar bridge. Can anyone tell me how they come out other than counter clockwise. Or is this the problem you were talking about. The book just says remove the special bolts.
Montreal
2009 ST1300A9
They are only special because they have holes drilled and tapped in the heads of them to allow them to accept the screws that hold the decorative cover on.
Other than that they are not special, no different than any other bolt.
