Can I use normal mercury carb styx for the starter valve sync. on my ST1300?
I've had the carb styx for years.
Yes you can - That is what I use on mine. But I modified the circuit to make the connections easier. I lengthened the circuits and ran them to the front of the frame. The yellow tygon tubing is what was added.
Dave,
But the intent here is to replace the 5 way connector with a new one, in the new location, right? Along with relocating all hoses to a more convenient location.
Thanks for the info
Andrew
That's the IAT sensor. It connects to a socket on the top of the air box after you've installed it.Im struggling to rewire harness after overhaul, do you know/remember where long wire white connector at bottom left of picture goes?
98k for me, never even had the air box off the bike. No need.
- How does a person know if they should have their starter valves synched?
- Is there some type of indication from the engine or throttle response that indicates a synch is necessary?
I am over 90K and have never had my starter valves synched.
