What do you guys think about the R1150RT vs the R1200RT ? I have found a very nice 05 R1200RT with only 3000 miles. A lot more money tho.
I have had both... currently ride the 1200RT. Love it. It is a significant step up from the 1150RT in several key areas:
1. Cruise control. Nuff said.
2. Lighter
3. Counter Balanced Twin, so it is smoother than the non-counter balanced 1150RT
4. More horse power (95 BHP to the 1200RT 110 BHP)
5. Better lighting
6. More comfortable cockpit... there is NONE better. NONE.
7. Slightly bigger luggage capacity (slightly, especially with the available 49L BMW Top Case)
8. CanBus (some will disagree here, but I think the simplicity of this electrical system allows for better reliability over the 1150 wiring harness... have you seen that before?)
9. ESA, if so equipped is very nice. Not available on the 1150RT, although a good set of Ohlins will cure that.
10. Subjective things follow: Better looking, I get more compliments on the 1200RT than either my old 1100/1150RTs or the ST1300 for that matter. More flickable than the 1150RT, probably due to the weight for one thing. I like the dash and readability over the 1150RT, especially with the Bike Computer option, integrated into the dash. Very complete info.
Couple of things on the 05R1200RT to check out... there was a recall on the EWS electronic immobilizer ring on the ignition switch (there is a VIN number range to check with a dealer, they can check that out)... make sure that this has been done. Also, there was a software and Oil level sensor update through early model year 06, that recalibrates the sensitivity and accuracy of the Oil Level sensor if the bike has the Bike Computer option.
Good luck. If you get it, you will like it, if not love it. Mine has 30,000 miles in just over 2 years and am still getting the grin everytime I ride it.
