I wanted to have the option of riding with or without my top box
and I have a powerlet bulkhead kit already hooked up to it so I wanted to take advantage of that.
Here's the bulkhead kit - connected directly to the battery w/fuse and
connectors to make them easy to connect/disconnect - click the
picture to go to the powerlet site.
http://www.powerletproducts.com/product/basic-luggage-electrix-tankbag-saddlebag-power-kit/288
I looked all over the saddlebag and found one spot that appeared like it would work.
I used the retaining ring that came with the kit as a template for
cutting the plastic.
I took a deep breath and plugged in the dremel too.
The bulkhead part of the kit.
I don't feel it's really needed but I did add some RTV sealant
just to ensure no leaks.
Put the screws in.
Install retainer ring and locknuts and tighten.
Now you can hook up whatever powerlet adapters you have, the kit
comes with an SAE and standard cig lighter connector.
View from outside.
I routed the battery connection over from the battery to the left
side of the bike.
I routed the wire down the frame and also made sure to leave some slack.
You can now look up power to the saddlebag using a secure and watertight connection.
