Article [13] ST1300 - Fairing Removal
002760
Mike (Dorian) did an excellent write-up on the ST1300
Fairing Removal and gave me permission to post it here.
Thanks Mike!
Note: Since the site was down and links not working I attached the PDF files.
Gug
Trenton, MI.
18' Goldwing Tour
Re: ST1300 Fairing Removal
Excellent write up and pics. I will even be able to do it now. I know from what the manual has in it, I sure wasn't going to take a stab at it.
Thanks Mike for the instructions and Joe for the post.
Switzerland, 9472 Grabs
ST 1300 ABS,
Dear Riders
I just must say the same words as they are said before. Good work also for a guy in Switzerland.
Best regards.
Thomas:D
NC
Thanks to Mike for writing this up. I just zipped mine up from a week of farkling and service. These instructions are excellent!
Moorpark, Ca
2008 ST1300A
7850
yes , they are great ! Used the instructions to remowe left fairing in order to get to the QH and change the Power Outlet fuse. Take your time - it is still intimidating when all those bits and pieces are laying on the ground (preferably on some tarp)
Natchez, MS
'07 ST1300
THANKS MELLOW
this might come in handy for this HOT summer weather
I hear removing the lower cowling helps reduce the engine heat coming back on the rider
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
A keeper box with compartments labeled for each panel helps immensely and makes the process of reassembly go a lot quicker.
--Mark
Bradenton, FL
'06 ST1300
6854
I printed it out and marked how many pushpins, screws, etc. went to each section. Made putting it back together much easier.
Laguna Beach, CA
2004 st1300
How are the trim clips (mentioned in the write up) removed? I assume these are the ones with the mushroom head? Do you lift up on the mushroom and then remove the clip or do you push the mushroom in and then remove the clip? Already figured out the push type (after breaking one)
TIA
Laguna Beach, CA
2004 st1300
TIA
Are there more than 2 types of plastic clips/pins on the 1300?
002760
There are two basic times on the pre2008 models... one is the button/mushroom type where you pull the center out (there are two sizes of these) and the other is the push pin type where you push the center to release it and then using your fingernail or thin screwdriver wedge it out.
In 2008 they added a 3rd type that has a phillips screw head look to them and they sort of look like the push pins but act like the button type.. you unscrew them and then grab that unscrewed portion and pull.
Hope that helps.
Laguna Beach, CA
2004 st1300
Hope that helps.
Thanks, didn't want to break more trying to figure it out.
002760
It doesn't hurt to order some anyway... sooner or later, you probably will break one... I have a few loose ones handy just in case.
demarest, nj
2007 ST1300
Re: ST1300-Fairing Removal
Wow. What a fabulous link for the step by step fairing removal! I still plan on getting a service manual for the bike, but this gets me moving forward in the interim with confidence. Thank you very much!
Steve
Outbackwack
Howard
Phoenix, AZ
'13 Vstrom 650
8055
This is the info I used for my first tupperware removal. The only thing that's missing is the removal of the nose cone/headlight assy.
Beaumont, Alberta, Canada
Thank you so much for these pictures and the great instructions. I probably wouldn't have had the nerve to take all the skins off without these great tips. Everything came off, then back on again in an afternoon. Not bad for a first time!! Thanks again, what a great informative site this is.
fiziks
I brake things.
Tropical (as in "southeast") Minnesota
2003 ST1300A
When removing the left mid fairing, if the Honda grip heater is installed with the control pad just below the left side glove box, there are three wires coming from the control unit that have individual disconnects covered by a rubber sleeve that looks enough like heat shrink tube to fool you into thinking you might have to cut the wires.
Olympia, WA
2003 ST1300
What size are the pushpins? I need to buy some more and Lowes and Ace stocks them. Thanks!
