Article [13] ST1300 - TupperWare Worksheet
S Cal
What do you do with all the fasteners when you take off your Tupperware?
Well I made these worksheets to keep track of mine.
The idea is as you remove the fasteners, you place them on the correct spot on the worksheet. It helps me keep track of all the parts and it reminds me of all the fasteners that have to be removed first before you try to pull the piece off. Also, each fastener is numbered so you can see the location where it came from - and where to put it back.
Note, I have labeled some of the socket bolts as 5mm or 6mm - this is the thread size. Also there are two different sizes for the trim clips - one has a golf T shaped head and the other is flat.
This is what the sheets look like loaded up:
3rd worksheet added:
Here are the links to the full page pdf files:
Page 1
Page 2
Page 3
1-13-2012 Update
"The Dan" added numbers (in red) for each fastener and wanted to share. Here are links to the files - (Thx Dan)
Page 1 (with numbers)
Page 2 (with numbers)
Page 3 (with numbers)
Brisbane, Australia
Re: TupperWare Worksheet
Now that is a bull tearer of an idea! Already printed, laminated and installed on the workbench.
Great job.
Regards
MG
St. Albans, Vt.
BMW R1200 GSA
7440
Great idea!
I've always put the rivets and bolts into an egg carton in the order in which I removed them. But I'll definately convert to your method.
Thanks!
jwayden
John Wayden
El Paso, TX
2007 ST1300A
7296
Great idea John, and very well done!!! Thanks for sharing!!! :hat1:
scootac
Will Ride for Food
North Central PA
DAYUM!!!
With something like this, even I might be able to undress 'er!!!!
THANKS!!!:bow1:
Tom Mac 04a
LI , New York
04 ST1300a
8347
Yes, very nice.... I usu use an egg crate or some double stick tape to hold the buggers.
Double Oak, TX
BMW K1600GTL
5866
Very impressive. I've used little snack size baggies that are labeled, but I like this a lot better.
Jefro
I ride to Sturgis
Kalifornia
I thought I was organized, but you are GOOD! Thanks.
Jefro.
