All,
Had my 2007 FI light come (12,000 Miles) on at different mileages. Not on all the time and Code 26-Right t Knock Sensor. I pulled off the fairings etc and looked at the wiring to the sensor and did not see any heat issues after doing my research. After a couple rides I reluctantly decided to take it to the dealer three weeks ago and when riding to the dealer it came on early in the ride. When the light comes on you can notice a change in the engine (slight hesitation or trouble spot). The "dreaded dealer" changed the right knock sensor and then call and told me that it was not the problem. They said they checked all the wiring, etc. and no shorts. Next option is the dreaded ECU. Told them to go ahead and they installed it and told me it is working up to specs. I picked it up on Saturday. $1,200 and change later.......no problems yet..................mechanic told me that 9 out of 10 times it is the ECU. Let's see. Anybody have any experience with this issue? I researched but saw only a few issues mostly with heat issues and left and ride sensor mix up on earlier models. The 2007 has a spiral metal clip that keeps the wires away from the engine.
You would think that Soichiro and his guys would have fixed this issue as an ECU is about $800 a pop.
Best to all.
Best to all.
