Hi Merl:
I'm 99% sure that the problem is caused by either a blocked five-way tee in the midst of the throttle bodies, or a problem with synchronization of the idle airflow into the throttle bodies. There's a 1% chance the problem might be caused by failure of some other part, such as a bad spark plug or bad coil, but that is unlikely.
Here's a link to an article that explains how to synchronize throttle bodies:
ST1300 - Throttle Body Synchronization Unfortunately, the photos that were embedded inline in that article are now all down at the bottom, which makes it a bit difficult to follow, but the information there is good.
You will need a manometer such as a
Morgan Carbtune in order to synchronize the throttle bodies. I'm pretty sure someone in the lower mainland area or on the island will have one - just throw up a flare in the BC forum here asking for help. Failing that, I am sure that someone who will be coming to the
WeSTOC Rally in Calgary in late June will have one - if you plan to go to that rally, post a request in that thread for someone to bring their manometer.
But, before you go to the trouble of balancing airflow into the 4 throttle bodies with the manometer, take the bike apart and clean the five-way tee with a pipe cleaner. There is a good chance that that action alone will solve your problem.
It's not easy to get to the five-way tee. You need to lift the upper fuel tank, remove the air filter, remove the snorkels, and remove the lower portion of the air filter housing. To get the snorkels off without stripping the screw heads, you need to have a
JIS (Japanese Industrial Specification) screwdriver. The screws that you think are Phillips head are not Phillips, they are JIS, and if you use a Phillips screwdriver on them, chances are you will strip them. So, before you do anything, order a JIS screwdriver. They cost about $20.
Below is a picture that shows the five-way tee. It connects a bunch of vacuum hoses. This tee gets plugged up over time, and vacuum cannot flow freely and equalize between the hoses. This leads to rough idling. The tee is somewhat fragile - a new one costs about CAD $10 - it might be prudent for you to order a new one before you take the bike apart, just in case it breaks when you are pulling the hoses off. The part number is
17201-MCJ-003 . At the same time, you might want to order a roll (1 meter long) of bulk vacuum hose, in case the hoses that connect to the tee are plugged. You can clean the tee out with a pipe cleaner, but it is a SOB to try and clean hoses - it's a lot easier just to replace them. A roll of vacuum hose, part number
95005-35001-20M , costs about CAD $12. If you replace the hoses, cut the new hoses about 2 inches longer than the original ones - that allows them to sit up nicely in the middle of the throttle bodies, like you see in the picture below, and gives you easy access to the hoses when you do the throttle body synchronization.
Once the five-way tee is cleaned and the hoses are cleaned (or replaced), you can then do the throttle body synchronization. When that is done correctly, you will be able to balance a nickle on its edge on the gas tank filler cap when the engine is idling.
Regards,
Michael
Five-Way Tee with Vacuum Hoses
