I have a -2015 Pan that shows symptoms or runnig lean in some rpm areas. I read about a modified fuel pressure regulator that improves the lean spots. Is that mod still available? I can not find any supplier
Do you still have that TC FP regulator lying around by chance?I think I have one of Tom's original modified (58 PSI) regulators lying around if anyone is interested.
Hi Tom,Hi, the factory original regulator is not adjustable, but the pressure can be changed by slightly crushing the top (spring area) of the regulator- raising the pressure. must be done carefully as it can not be undone. you must also come up with a way to measure the pressure as the modification is done. i have done quite a few one off regulators this way.
can provide more details if required
Thanks Tom
I literally just gave it away a couple of weeks ago, sorry.Do you still have that TC FP regulator lying around by chance?
Wondering why you never installed it? I'm going in under the tank soon to install my new MC cruise control and K&N.
Cheers,
Mike
No worries, thanks for the quick reply Jeff,I literally just gave it away a couple of weeks ago, sorry.
Tom would you have a list of the pressures of the regulators you used to mod for the ST? As I recall you sold a few different pressures.here is a write up i did for the Africa Twins-- the set up is different but would be done at home the same way
DIY Fuel Pressure Modification
I am in the final stages of testing a solution to the stalling/ rough running issue (and other running problems) I have a 2017 tri color that i have installed a modified fuel pressure regulator. Some back ground, I owned TurboCity (retired 2 years ago) and have designed and built modified FPRs...www.africatwinforum.com
Funny thing, the guys with the Africa Twins are completely disinterested in the FPR mod- works excellent on my 2017- its their lost.....
Thanks Tom
