okmurdog
Will Ride for Pie
I just performed the 16k valve check on my bike....twice.
Let me explain (a bit long, but unusual) -
I first checked the valves at 16,050 miles. During this check, I found three valves out of specification, and several others were technically in specification, but were close to the 'low' side. I measured ALL of the valves using two different feeler gauge sets (English and Metric). I first performed measurements on all valves using the English set, and started all over again using the Metric set. The English set is graduated in 0.001 inch, whereas the Metric set is graduated in 0.01 mm. Both sets of feeler gauges confirmed the out of spec valves.
During this first inspection, I rode it home from work on a Friday afternoon & pulled the tupperware. I performed the valve clearance inspection the following day. Ambient temperature in the garage was around 48? F.
I ordered a Hot Cams shim kit, and several other parts recommended by Honda that should be replaced when the cams are pulled.
While waiting on the parts to arrive, I was somewhat bothered by the findings of three valves out of spec, and several valves close to tolerance. I have read many accounts of folks finding the 16k valve check in tolerance, with no adjustment necessary.
I started thinking of any scenarios which might cause the valves to be out of specification. I ride my bike nearly every day, mostly to commute back and forth to work. The trip is a combination of 7 miles of country roads (with stop signs every mile), 8 miles of 55 MPH non stop roadway, and 7 miles of stop and go traffic in the city.
I wondered if it were possible there was any carbon build up on the valves, since I had not done any 'open road' riding in nearly two months. I buttoned the bike back up and ran some Seafoam thru a tankfull of gas. I really didn't expect the Seafoam to change anything, but I figured I would give it a try anyway. I ran the bike on long non-stop stretches of roadway with speeds mostly from 60 to 80 MPH, and burned thru a full tank of gas (~300 miles)
I tore the bike down again last night in preparation to adjust the valves today. I had all the parts in hand and was fully ready to tackle the job.
I measured the valves first thing this morning, and all of the valves are now within specifications!
I don't know for sure what could have caused the change. The only differences were: Seafoam thru a tank full of gas, and the ambient temperature around 70? F.
I really don't think either of these (Seafoam or ambient temperature) could have made such a difference in the valves. I think Seafoam is a good product, but I wouldn't fully expect it to clean carbon from an engine in just 300 miles thru the gas. However, I will use it in at least one tankful before performing the next valve check at 32k.
Anybody else had an similar experience?
