1991 ST1100 Water Pump
Fort Worth, Texas
91 ST1100/06 ST1300
I'm building up a set of likely spare parts for my 1991. Been keeping up with the rebuild of the ST1100 water pump so I started checking.
Partzilla shows that for the 1991, water pump number 19200-MT3-000 is obsolete. Water pump for the 1992, number 19200-MY3-010 is still available (1992-1994). Both years have the oil cooler collar at the oil filter.
What's the difference between the two pumps?
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
The USA 91 pump does not have a pass-through port and nipple for the 92-95 engine's internal crankcase breathers' output (front of right head) . 91s' engines vent crankcase air/vapor out a port at the rear of the engine to an external breather chamber (by your right shin).
I can dig up some pictures if really needed. Bottom line though - 91 pump in 91s only. 92-95 pumps fit a 91 just fine, I've seen one installed. No problem. The extra port is unused.
via iPhone 6
Oldbikefixr
Fort Worth, Texas
91 ST1100/06 ST1300
The USA 91 pump does not have a pass-through port and nipple for the 92-95 engine's internal crankcase breathers' output (front of right head) . 91s' engines vent crankcase air/vapor out a port at the rear of the engine to an external breather chamber (by your right calf).
via iPhone 6
That's what I was hoping for, John. No photo necessary. New parts for a 25 year old bike will soon begin to thin out. Didn't want an unusable spare in my stash. Thanks.
