2000 ST1100 Starter Switch No Longer Availalbe
Calgary Alberta Canada
Hi, My starter switch does not work and we cannot find replacement as they no longer make them. Anyone have any suggestions on how to fix or replace. Part number is 35013-MAJ-A32. Thank you.
I managed to order a new one. Hopefully it makes it. Thank you
Yes that website worked. I ordered a new one. I had ordered a new one from Bike Bandit, then they went bankrupt and kept my Money. Hope this one comes through. Thank you for the advice.
British Columbia
2021 RE Meteor 350
Wondering if you called them to ensure the part was actually in stock?
Smudgemo
Intermodal Man of Mystery
Berkeley, CA
'08 GS / '78 CB550
Just out of curiosity, are you sure it was the switch? When mine stopped working, it was the starter solenoid that went bad. It was infrequent, then got progressively worse. Super-easy to replace.
Uncle Phil
4 ST1100(s)
002064
698
While you wait, you might take the switch loose and check to see if you are getting 'fire' to the connectors.
The problem with a lot of websites for ST1100 parts is they say they have it 'online'.
Then when they order it from Mother Honda (because they carry no stock), they backorder it with a 'who knows when' arrival date.
Hound
Cave Canem
Wales, UK
2004 ST1300PA
4607
Gerhard
Ontario
2012 R1200RT
In the last days of owning the ST1100 I occasionally had to give the bike a slap on the Tupperware that covered the battery. First few times I took the cover off to find that it cranked with out doing anything else then I just caused a little vibration and it would crank.
Montreal
2009 ST1300A9
Wonder if this part was only on the ST1100? Honda will often use the same part on lots of bikes might be able to retro fit one off a Shadow or some other model.
According to the parts fiches, P/N 35013-MAJ-A32 is unique to ST1100 1995-2002 and ST1100 ABS 1996-2002.
You may find this part from this source
An excellent caveat. When looking for some discontinued parts for my ST there were myriad sites showing what I wanted and allowed me to place an order and they took my money. A day or two later I got an email stating the part/parts was/were discontinued and the money they took instantly would be refunded in a few day — please allow up to ten... etc.
So when someone says a part has been discontinued absolutely order anyway because a site doesn't say so and will take your money. Just don't expect to get the part(s) and you won't be disappointed when you refund. If you do get the part then Happy Days!
Ron
Orlando
ST1100s
2432
Have you tried spraying electrical contact cleaner in it?
Is the kill switch part or the 'start button' that does not work?
I don't buy parts until I do an electrical troubleshoot.
Have you tried trouble shooting at all?
I've solved the same problem by flooding the internals of the switch pod with a can of WD-40 and the red tube. Catch the overflow with a rag. If this solves your problem, you know you don't need a switch. This fix last many years for me.
Ron
Orlando
ST1100s
2432
Have you tried David Silver Spares? They have many out of production parts.
British Columbia
2021 RE Meteor 350
To save the OP's time, I did check both the UK and US sites for them, with no luck.
illinois
2000 ST1100
Might want to call a place like Digi key.com. They have thousands of micro switches. One of the things I like about them is you can get a real person that will help you get the right switch. Check em out.
