I have been a member of this forum for a while and have not posted much. I have learned a lot by reading a lot of the brake post and many other post here.
My rear brake locks up when I press medium pressure on the rear brake every time. In short the bike was stored outside always under a cover for four years and driven very little. Then Stored inside a storage unit for two years. Took it out for a spin and rear brake locked up and the heat ruptured one of the rear hoses.
I ordered rear seals, rear stock brakes and new hoses. Put everything together, bled all the brakes at all points front and rear in the proper order. Rear still locks up. I read a lot on the site about front brakes and SMC.
At this point I took both front brakes and SMC apart. Had difficult time removing pistons from left and right front cylinders. I ordered new seal kits, brake pads, SMC rebuild and new pistons(old ones damaged so bad removing had to order new pistons).
All the bores on all calipers(front and rear) and the SMC were smooth and clean prior to installing new seals and pistons. THE REAR PISTONS WERE NOT REPLACED but were NOT CORRODED or pitted.
I cleaned and rebuilt the front brakes and SMC with all new stock parts and bled all brakes front and rear following proper order.
Rear brake locks up with light to medium pressure on the rear pedal. Wheel will not move. The rear rotor was damaged during the first brake incident and I cleaned up the rotor with light sanding even on each side while bike in first gear on center stand. IF I VENT THE REAR CYLINDER THE PRESSURE WILL RELEASE and the wheel is free again.
I am asking for help. I can only imagine that the only thing left is the Rear Master Cylinder needs a rebuild??
I am an accomplished electrician and mechanic starting in the US Navy for 12 years and 11 years as a multiskilled technician in a Bridgestone/Firestone tire factory. I drive Commercial trucks now. I really do not want to pay the stealership to do the repair when I have come so far. I need some help from those of you who have solved this issue for folks in the past. I want to spend money in the right place on this repair. Thank you.
