Hi, and welcome !
I can't argue with what everyone else has said so far, but i'll add an alternative. Check the rear wheel and disks carefully. Run your hand or a spirit- damped rag over the surfaces.
You are looking for a thin layer of grease, which may be caused by the incorrect grease being used in the wheel bearings, or by a workman with dirty hands. Wrong grease or over- greased bearings will spin-dry their contents over the wheels and disc surfaces. The discs may clean themselves, but the pads will be well lubricated.
To cure, take the pads out, take the wheel out. Gently prise off the oil seals and clean out as much of the grease as you can. The bearings are sealed anyway, and most of the lubrication they need is trapped inside. The seals and the spacers need just a smear. Degrease the disc. Take a good look at the pads. They may need to be replaced, but sometimes it is adequate to clean them by rubbing the surfaces back and forth lengthways on fine wet and dry laid on a smooth flat surface.
Hope you get it fixed.
