davidrider
Kungfu Panda
Starting a new review for my 2017 Road King (my Softail Classic review is closed). To begin, there have been big changes to the HD touring line in 2017 and softails in 2018. I cannot speak to the softails but I will gladly review my relatively new Road King. I'd have to say if there was anything you didn't like about HD's before (other than the dealers) it's probably changed for the better. Some of these changes are overdue but better late than never.
Previous type complaints:
HDs run too hot - the Road King has oil cooled heads and it has an oil cooler with a thermostatically controlled fan. The M8 also idles at a lower speed (850 rpm) thus burning less gas and generating less heat. The catalytic converter and pipes have been relocated to keep heat away from rider and passenger. It's the coolest bike I've ever owned (pun not intended, really) and yes I rode an ST 1300 and many other bikes for a while.
Engine performance - now 4 valves per cylinder, oil/liquid cooled for more consistent performance and you get 111 foot pounds of torque right out of idle and through the whole rpm range. It's not a sport bike but it'll loosen your arm sockets.
Poor suspension - Showa provided an all new setup that improves performance and comfort. No more leaky air shocks. Remotely adjustable preload that can be set higher than before for extra-hefty passengers plus gear. It's confidence inspiring in corners.
They vibrate - the Road King engine is both counter balanced and rubber mounted. It is the smoothest, least vibe-y engine I have ever rode. The smoothness of the engine greatly improves comfort and ride-ability. Even on the stock seat, sitting on this thing for hours is no problem. No bad vibes period.
Mechanical noises - these have been all but eliminated to allow for a new rocking exhaust sound (sorry to those that loved the potato but I love this new sound).
Other cool things:
Valve adjustments required... never
Better gas mileage to boot (45 mpg for me).
A lot more electric power for accessories.
A gear indicator (sorry ST).
Standard cruise control (again sorry).
The stock windscreen is amazingly perfect for my 6'1" frame but my favorite part is it can be easily detached.
So far I haven't found a thing I don't like about it. I might keep this one for a while...
Other cool things:
