28 amp alternator removal help
Malaysia
ok after the welding, things skrew up , due to the welding heat, the internal bearing gave away, the alternator does spin freely, look like i need to replace the bearing
Malaysia
anybody know how to remove this bearing IMG_20131203_183222.jpgthis is the rear small bearing facing the back cover
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Counter clockwise to remove the left swingarm pivot bolt lockring.
Only one of your attachments in posts 22-24 is showing up, and clicking on them results in a dead link... :(
anybody know how to remove this bearing this is the rear small bearing facing the back cover
A small bearing-puller, 2- or 3-legged:
When installing the new bearing on the shaft, ensure to put force only onto the inner race.
Clean and lube the shaft end, find a fitting socket or pipe and a small hammer to tap that inner bearing race on.
Malaysia
thanks ST1100Y, will look for the tools and try do my self, worse case i'll send to machine shop
