lol....my thoughts EXACTLY
. the 'highly respected for electrical skills' was an IMMEDIATE red-flag
Yeah... I was hesitant... ;-)
The "...has
concluded the alternator must be replaced..." kinda gave it away...
So again: before starting to order expensive spare parts and replacements, I'd cover the basics to eliminate all "simple culprits" first:
- battery tested, fully charged and terminals firmly attached
- voltmeter test on battery terminals: should read between 12.6 to 15.0V (later @ ~5000rpm)
- condition of mains-winding stator connector/plug
- condition of mains wiring
- condition of connectors on bottom of VRR
- conditions of bike wiring harness
any signs of corrosion, overheating, melting or burned wiring must be properly addressed...
Discolouration of the insulation and hardening of the copper strands are clear signs of corrosion caused increase of resistance, thus overheating...
Once any wiring related issues are off the table, continue with measuring resistances
(keep in mind that the 28A alternator is a 3-phase system, thus 3 identical power windings, thus 3 identically readings must be found)
- resistance between the 3 yellow wires: ~4.0 Ohm
- resistance between (any) yellow and ground: infinite
- resistance between (any) yellow and white: infinite
- resistance between (any) yellow and red/white: infinite
Measuring protocol of the VRR is a bit more complex, dunno if the Haynes fully covers it
ID the prongs by the colour of the wires in the big 6 pin connector shell, detach named, then take measurements on the VRR's prongs:
- yellow - red/white: 7.5 Ohm (3x)
- white - red/white: 60 Ohm
- white - yellow: 28 Ohm (3x)
- all other combinations: infinite
Then, to cover all, check the
AC output of the alternator:
- detach the yellow 3-pin and the black connector coming from the alternator
- start engine (will now run on battery power only)
- carefully measure the voltage at the 3 stator sided, yellow wires.... IIRC something ~60V
AC (set voltmeter accordingly!), and again: must be 100% equal on all 3 windings
